Roto-Fab
Old 03-07-2022, 07:05 PM   #1
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
BTR Shaft Mount Rockers
Has anyone used the BTR shaft mount rocker kit?
1. Did it change push rod length
2. Do they fit under the OEM valve covers
3. An has anyone used the TSP roller tip rockers on them?
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components.
olblue75 is offline   Reply With Quote
Old 03-11-2022, 01:08 PM   #2
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
I did not, but it looks very promising. It think I saw someone on ls1tech that did.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 03-11-2022, 02:43 PM   #3
demonspeed
not afraid of the wall
demonspeed's Avatar
Drives: Camaros
I just did. Check out this thread on LS1tech for more info. I didn’t start the thread but I commented later.
https://ls1tech.com/forums/generatio...225-heads.html
To answer your questions:
1) It theoretically shouldn’t change pushrod length. In my specific case, I swapped cams from a BTR4 to G6X3 and added Johnson link bar lifters, valve job, etc, so the change in PR length for me isn’t going to be indicative for a basic cam swap.
2) Yes, without issue.
3) I just used OE rockers.
Unfortunately I don’t have any feedback yet on how they are with a running engine Hopefully I’ll have this stupid car back together in the next week, though and I’ll comment back.
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100
Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z
demonspeed is offline   Reply With Quote
Old 03-11-2022, 06:34 PM   #4
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
Very curious how those Johnson Link Bars work for you, as those are exactly what I am looking at when I get into the engine again. I am looking forward to ditching the lifter trays.
Hey, if you don't mind me asking - which brand bronze bushing were you using that caused the failure?
InFiD3ViL is online now   Reply With Quote
Old 03-11-2022, 08:29 PM   #5
demonspeed
demonspeed's Avatar
Drives: Camaros
I don’t actually know which bronze trunnion kit as it was installed by the previous owner 50k miles ago.
I know we don’t hear much about the bronze bushings failing, but in my case it was 50k very hard miles supporting an aggressive cam street racing, drag racing, and road racing. I feel burden to some responsibility waiting so long to change them out.
As Tiger King once said, “I am never going to financially recover from this.”
10/13/22: 1100
Old 03-16-2022, 04:06 PM   #6
brick59
Sucker Punch
brick59's Avatar
Drives: 2013 Black ZL1, 2007 Silverado LTZ
[QUOTE=InFiD3ViL;11144999]Very curious how those Johnson Link Bars work for you, as those are exactly what I am looking at when I get into the engine again. I am looking forward to ditching the lifter trays.
I don't have Johnson's lint bars I have Morel link bars both very good companies, my motor goes 6800 to 7200 rpm depending on track conditions
never any problems I have about 5000 miles on it. only reason I went with Morel's is I have a Cam Motion solid roller cam Johnson didn't offer them.
Building a new motor it's going to be a twin turbo 427 that will turn 7500 to 8000, going to definitely run link bars again.
427 Dart SHP Pro LS Block, Callies Magnum Crank, Callies Ultra I Beam Rods, Diamond Pistons, AGP twin Turbos 6865, Mast heads, Cam Motion LLR cam, Morel tie bar lifters, Crower roller rockers, NW 103MM TB, ID2600 XDS, Fore Triple, DSX, E85, ARH Turbo Headers, Corsa, Jakes stage 5 4L80, Circle D, RPM Roll Bar, BMR, Carlyle Racing 15" conversion kit.
brick59 is offline   Reply With Quote
Old 03-16-2022, 11:02 PM   #7
RS/SS '10
Drives: 2010 2SS/RS
If they are aluminum roller tip rockers, chances are really good you will need tall valve covers, I did.
RS/SS '10 is offline   Reply With Quote
