Old 03-20-2024, 01:09 AM   #1
Daler
Drives: 2023 Camaro ZL1
Roto Fab Big Gulp vs Corsa Carbon Fiber Intake
I previously spoke on this forum about boost limits on 93 octane. And now since I’ve got that settled, I’d like to know if there’s a real true difference to adding a big gulp vs using the corsa intake I already have. The car is fully built from the bottom end all the way up with everything you could think of ported as well as a interchiller and a bigger throttle body. Will the big gulp really add a substainal HP gain to my build or should I just stick with the corsa and call it a day?
Daler is offline   Reply With Quote
Old 03-20-2024, 07:36 AM   #2
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
Do you already have a 103mm TB?
GM Gen V Calibrator
Old 03-20-2024, 08:24 AM   #3
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
If you have the 103mm tb then yes Big Gulp is definitely worth it over the Corsa.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 03-20-2024, 09:12 AM   #4
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Is the Corsa a 4" tube while the BG a 5" (reduced to something like 4.5" at the MAF or something)?
I know I had to change my MAF curve when I changed from the standard RF to the BG. Not only because of the delta of the tube diameters, but my airflow went higher, too.
'20 ZL1 Black "Fury"
Old 03-20-2024, 09:18 AM   #5
KingLT1
KingLT1's Avatar
It says no tune required so that would be stock diameter because anytime the size changes you have to rescale the MAF in the tune.
2016 NFG 1SS A8
Old 03-20-2024, 01:59 PM   #6
Daler
Yes
Old 03-20-2024, 02:00 PM   #7
Daler
Yeah that’s what I thought, my performance guy said that it would probably only add like 5-10 whp if I added a big gulp and for $500+ it wouldn’t seem like that’s worth it at all.
Old 03-20-2024, 02:03 PM   #8
Daler
Do you know anyone one here that has a used one for sale maybe in the 400 under price range? not really wanting to spend 500+ on a intake again 🤣
Old 03-20-2024, 05:06 PM   #9
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Agreed!
The more you push the car, the more the Big Gulp is worth it over the standard Rotofab. If you’re staying 700 WHP or under I probably would not bother. Depends on your plans for the car.
Old 03-20-2024, 05:33 PM   #10
JSH
JSH's Avatar
Drives: '20 ZLE
Hennessey installed my standard Rotofab on their 850, and I believe I went to a Big Gulp with a 6" inlet tube when I changed to 112M TB
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650.
100+ octanes, no eth, no meth, no N2O.
2/23 - 1031/1004 wheel.
4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes).
2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next.
Old 03-20-2024, 06:18 PM   #11
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
You need to tune when you go over the factory diameter
