03-11-2015, 06:25 AM | #1 |
Drives: 2010 1LT Limited Edition Camaro A6 Join Date: Aug 2011
Chrome paint in a can?
I am wanting to paint my grill as close to chrome as possible
it doesn't need to be perfect or even have that "super shiny chrome finish" I just want it to look decent from about 10 feet away (Right now its black) but I want it close to it as possible without spending 130 bucks or something for a kit.... I was just wondering if anyone used a can of paint from home depot or walmart and had good results. Help me out gents!
2010 Camaro Synergy Green Edition V6/A6: Cold Air Inductions Intake, Trifecta tune, BBK long tube headers and Hi flow cats, MRT V1, Ported Throttle Body, Stage 4 Ported Intake Manifold (MACE), Black Ice-olator Intake Manifold Spacer, Plenum Spacer, Nytrex Triple Threat Nitrous.
03-11-2015, 07:17 AM | #2 | |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
03-11-2015, 07:28 AM | #3 |
Well, I mean what about a nice metallic silver or just plain silver paint?
03-11-2015, 07:32 AM | #4 | |
Silver paint would work better, but do you really want a rattle can painted grill. After a few thousand miles of bug guts, it is likely to look pretty rough.
03-11-2015, 07:33 AM | #5 |
Drives: 2018 Hyperblue Camaro 1SS/1LE Join Date: Feb 2015
03-11-2015, 07:56 AM | #6 |
WHAT RED LIGHT?!
Drives: 2011 Black Camaro 2SS/RS M6 Join Date: Apr 2011
Canned paint is crap...For $100 more take it to Maaco. They can do a small job like that and comes with a 2 to 4 year warranty...I forget.
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
03-11-2015, 08:03 AM | #7 |
Drives: 2014 Summit White LS Join Date: Mar 2015
Chrome paint is really terrible to try and paint with. If you really really know what your doing (and 95% of people don't) you can make a rattle can job look passable. That involves a lot more expense then just a can of paint and a crazy amount of time. Do it right and have it chrome plated, professionally sprayed, or buy a different grill. You will be happier in the long run. It's not a '93 Honda Civic.
03-11-2015, 08:05 AM | #8 |
PLASTIDIP - Easy to apply, and it is removable. I've used it for my emblems, and will soon use it for my front splitter and even my wheels.
Ordered a wheel kit from dipyourcar.com for $50 which comes with 4 cans of matte black and one can of silver metalizer for a top coat. Long story short - awesome, customizable color options for a cheap price and easy application. A huge up-and-coming car paint modification. Some have even done their whole car. "Paint Is Dead" is their motto
03-11-2015, 09:13 AM | #9 |
Drives: 2011 1LT Join Date: Mar 2012
I have never seen any "chrome" paint out of a can that even remotely resembles chrome. It may have the same SHADE as chrome, but it has absolutely no reflective/ mirror- finish qualities like chrome does. It's just sort of a brushed silver look, at best.
03-11-2015, 09:41 AM | #10 | |
It doesn't need to have that chrome finish. just CLOSE something like this is even acceptable I just need it to stick to the grill... http://marcatiyolil.com/wp-content/u...p2-218x300.jpg
03-11-2015, 10:17 AM | #11 |
Then buy some 400 & 1200 grit sandpaper and sand the ENTIRE surface of the grill for the paint to adhere to so it won't flake off. if 400 leaves scratch marks too noticeable, finish it off with 1200 grit to smooth it a bit. Don't "dig" into it, just scuff it up. Then, wash it thoroughly to remove any dust and debris, let it dry. You could use rubbing alcohol to finish the cleaning process. WEAR LATEX GLOVES so that oils form your skin dont touch the grill after you've washed and dried it. Then paint. Not too heavy, not too thin. If you get a drip. Let it dry, and wet sand the drip out with 1200 grit. Viola!
Life is short, drive it like you stole it! |
03-11-2015, 10:33 AM | #12 |
Drives: 2014 2SS RS LS3 Join Date: Oct 2012
I got this stuff a few years ago called steel-it. it makes a silver, brushed steel look. very metallic
Thank our veterans for peace today, Support our troops for peace tomorrow. RIP Dad, 1962-2012 SYOTOS |
03-11-2015, 10:37 AM | #13 |
Drives: 2021 Shadow Gray 1LS Join Date: Oct 2011
Every "chrome" spray paint I've dealt with in the last 40 some years is a temporary fix at best.
Looks great wet, dries semi shiny, and the finish rubs off when dry. Especially the cheap stuff. I had one of my co-workers go apes-it with it in a boiler room one time. It looked like crap. I could see maybe bright argent silver- it would probably be a more lasting finish. |
03-11-2015, 11:11 AM | #14 | |
Drives: 2013 Camaro Dusk 2SS/6 Join Date: Sep 2013
I don't think it will look anything like chrome... but if you paint plastic scuff it up a bit and make sure you first apply an adhesion promoter like Bulldog.
there is some high end chrome paint they do for wheels... so I'm sure it can be done for plastic as well if prepped properly. and there is another process they rinse off parts with water. |
