Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 09-28-2018, 06:49 PM   #1
0-120
Drives: 2014 Camaro SS LS3
2014 SS Rough Idle, Service Stabilitrak
Originally Posted by 0-120 View Post
Update:
The issue was a broken pushrod & valvespring. Replaced these, got a CAI and a dynotune.
After a week of driving (in excess of 500 miles) I have gotten a code P0430.
Catalyst System Efficiency Below Threshold Bank 2
Does this mean the cat is gone? What are my options?
Please see the attached video. I can start it every time, but it takes awhile to crank. Engine light and Stabilitrak Service warning.
Significant power loss. Very rough idle.
Was hoping to go on a trip tomorrow...
416HP, 422TQ. Rotofab CAI, Dyno Tuned. ALP's and a V1.
0-120 is offline   Reply With Quote
Old 09-28-2018, 07:53 PM   #2
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Slow crank and stabilitrak message = weak battery
Old 09-28-2018, 08:11 PM   #3
0-120
How would this create rough idle and loss of power?
Old 09-28-2018, 08:28 PM   #4
Bandit63
Bandit63's Avatar
Drives: 2011 Camaro SS
Weak battery will cause a lot of crazy things
MRR M228 Wheels, Circle D 3200 Stall, 3.91 Gear, Texas Speed VVT 3.2 Cam, CHE Rocker Arm Bushings, Texas Speed Headers, No Cats
Bandit63 is offline   Reply With Quote
Old 09-29-2018, 08:10 AM   #5
Rock-It Man
Weak ignition or struggling fuel pump.
Old 09-29-2018, 08:47 PM   #6
marklsx
Drives: 2014 Camaro 1SS
Not sure if you have any experience working on these cars.
A new battery would be an easy first try, much cheaper than some of the other things it could be.
Flashing service engine light usually means misfire. One or more cylinders isn't firing for some reason. Not good to run the engine like this, the extra unburned gas will heat up the cats and damage them. I would get a cheap OBDII scanner and read the codes. This could give some good info.
Next I would remove all the spark plugs to see if any look odd/fouled. Or too clean.
Then I would take the valve covers off and inspect the springs, rockers and push rods. It's easy, just take off the coil packs and then the valve covers. Turn the engine over by hand and watch each one.
If all that looked OK, I would try to rule out the fuel pump and injectors.
And after that I would go internal.
2014 1SS - BTR Stg3, GMPP CNC Heads, Kooks LTs & cats, Magnaflow 2.5" Street w/Res X, Z28 CAI
marklsx is offline   Reply With Quote
Old 09-30-2018, 07:24 AM   #7
Gordy87
Gordy87's Avatar
Drives: 2010 Camaro SS
Has there been any modifications that you know of? And what area are you close too? You have Vengence Racing, LSX Atlanta, Spartan LSX, just to name a few of the bigger guys. Have you checked any of the items listed above yet?
Gordy87 is offline   Reply With Quote
Old 09-30-2018, 08:59 AM   #8
Rock-It Man
If you had only the engine warning light, I would be thinking ignition or injector wiring damage causing misfire.
But you also have Stabilitrak, which again, is a classic weak battery indicator.
Old 09-30-2018, 02:35 PM   #9
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
I had this exact thing happen to me on the way to the track. What caused it was a spark plug wire was touching the header. I re positioned it with a tie wrap and bingo. I'm not saying thats the cause of your issues but it does give you something to look at.
rontammy0 is offline   Reply With Quote
Old 09-30-2018, 03:44 PM   #10
0-120
Just replaced battery. No change.
Old 09-30-2018, 05:10 PM   #11
Rock-It Man
Do you have headers? They melt wires unless the wires are clad in insulating sleeves.
Also, if the plastic engine cover is still on, look under it. Rodents like to live there and chew on the injector harness.
Old 09-30-2018, 06:05 PM   #12
SSMickey
SSMickey's Avatar
Drives: 2010 IBM 2SS
If your engine is an L99, I'll bet you have a collapsed AFM lifter. Check your code and misfire data stream. The AFM lifters are on 1, 4, 6 and 7. If the misfire is one of those cylinders, pull the valve cover and have some one crank the engine and watch the rocker arms. If you see a rocker arm not moving, you just found your problem.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 09-30-2018, 06:14 PM   #13
0-120
LS3, no headers
Old 10-01-2018, 06:52 AM   #14
sdynak
Drives: 2010 1SS
can you list out all the codes you get? It does sound like maybe a rocker but please list the codes. It's not that long to pull the valve covers and the code may help identify what cyl so maybe only need to pull one for a quick inspection.
2010 1SS LS3, Black, 235/250, .621/.615, 114 + 4, Kooks Stepped Headers, 3.91's, Bo White PTB, Flowmaster Mufflers, Cold Air Industries CAI, Apex Scoop & Windshield Washer Relocate, SLP Wheels, Skip Shift Eliminate, Barton Flat Stick, OEM HID/Halos, Dyno Tuned by ECS
sdynak is offline   Reply With Quote
