Vararam
Old 03-24-2022, 11:06 AM   #1
kiteman
Drives: 2012 45th Camaro, 2SS/M6
can anyone diagnose what this sound is coming from?
2012 camaro ss m6, bought it brand new in 2011. has about 65k miles on it.
https://youtu.be/ztmgJOQrVFQ
kiteman is offline   Reply With Quote
Old 03-24-2022, 12:04 PM   #2
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
Probably your clock spring. It's the slip ring thing that connects all the connections in your steering wheel (including air bag) to the stationary harness in the dash.
My car has a bit of noise from it, also, but not nearly that bad.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 03-24-2022, 01:00 PM   #3
kiteman
is that easily replaceable and do i actually need to worry about it, or leave it alone?
Old 03-24-2022, 02:19 PM   #4
shibbs
Captain Gingerbeard
shibbs's Avatar
Not so easily replaceable. You'll have to pull the steering wheel, and usually requires programming after installation, or you'll throw ESC/Stabilitrack and/or air bag lights. If you can stand the noise, it's not going to cause any major problems, until a wire rubs through (may happen tomorrow, may never happen) and then you'll either lose steering wheel controls, or have an air bag light turn on, or both. The car will start, run, drive regardless.
Old 03-24-2022, 03:31 PM   #5
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
It doesn't require programming.
It only requires that you keep your wheels straight when taking off (keeping track of where you left it). Also, it has an alignment meter built into it, kind of like a sight glass.. But alignment and wheel placement, and keep the wheel straight during removal install is super important.
It's one of those things you really want to watch a few videos on and do some research before you attempt it, but its really not bad at all. Just need to follow instructions.
InFiD3ViL is offline   Reply With Quote
Old 03-24-2022, 05:15 PM   #6
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
It's NOT a slip ring. A slip ring would have contacts and brushes like an electric motor. Instead, it's a flex tape wound like a clock spring. When you turn the steering wheel, inevitably the wound up flex tape rubs together and makes a sound. The sound IS NOT a sign of malfunction.
It's NOT BROKE so DON'T FIX IT.
Old 03-24-2022, 11:25 PM   #7
kiteman
Thumbs up to all. Always helpful and I’ll leave it be for now. Thanks fellas
Old 03-28-2022, 07:34 PM   #8
Theloots
Theloots's Avatar
Drives: 2012 Camaro 2SS
Ever since I had mine ... about 5 years now .. I've had a similar squeak turning. If I got it fixed .. I'd probably miss the noise ! LOL. Go enjoy it !!
Texas Speed Long tubes, highflow cats, Borla Cat back S-Type, Spectre Cold Air Intake, HP tuner tune
Theloots is offline   Reply With Quote
