05-04-2020, 04:14 PM | #29 | |
Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
I agree. I try to fill it at 1/3 to 1/4 tank. Try not to let the red light come on.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers Delivered: 08/15/2016 #TeamBeckyD |
05-04-2020, 04:14 PM | #30 |
Shifts under load
Drives: 2020 Camaro 1SS 1LE rally green Join Date: Apr 2017
My 17 Camaro SS had about 2 gallons left when it said "low"
HPDE - southeast - JTI- solo, PCA- blue. 22 Suzuki GSX-S 1000GT blue |
05-04-2020, 05:12 PM | #31 |
Don’t go too long after the light and notice comes on as you will be calling someone to bring gas or walking to a gas station. Fair warning!
01-14-2021, 05:21 AM | #32 |
Drives: Chevy camaro ss Join Date: Apr 2020
Just filled up 18.6
01-14-2021, 05:36 PM | #33 |
to the forums, 2k16camaross.
Please heed the warnings posted earlier in this thread, you don't want to let the low fuel light come on. Happened to me once, but I try my best not to forget to fill up at about a quarter tank left.
01-14-2021, 06:13 PM | #34 | |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
At a track, I would totally not fall under 1/4 tank just to avoid the potential lean spike. For daily driving, you are probably fine. With these DI cars, it makes me wonder how hard these in-tank fuel pumps have to work, as it's the DI fuel pump at the engine that has to do most of the pressurizing work and that's driven by the camshaft. Just don't actually run out of fuel and I think you will be fine.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
01-14-2021, 06:27 PM | #35 |
Drives: like an old lady Join Date: Jun 2012
i drove 34 miles after the low fuel light came on. about 15 of which after it said "miles to empty: low". car was on ethanol at the time, as well. only managed to get 17.1 gallons in it.
stupid proof.
01-15-2021, 07:15 AM | #36 |
Drives: 2021 LT1 6spd Join Date: Nov 2020
I fill up between 1/8 and 1/4 tank, haven't used gas light.
Current: 2021 LT1 Camaro, 6spd, Crush, Corsa NPP, GMPP CAI, Soler Performance Throttle controller
Previous: 1997 V6 Camaro, 5spd, Black |
01-15-2021, 07:24 AM | #37 |
25 miles
'20 ZL1 1LE A10,
01-29-2022, 08:30 PM | #38 |
Drives: 2022 2SS Convertible Join Date: May 2011
Mine light came on. I drove about 6km to get gas. I was able to put 62.1 litres in the tank meaning at that point I had ten litres left, or 2.64 gallons. Which means you should be able to go about 80 km or 50 miles averaging 12L/100km or 19,6 mpg. That would be exhausting all fuel, however I would think some of that gas wouldn’t be accessible. Still a decent amount you’re able to go if needed.
01-29-2022, 09:37 PM | #39 | |
I had the light come on only once and only because I got stuck in a flash jam smack between two highway exits due to an accident. Of course I could've filled her up earlier, I tend to only let the gauge go down to a quarter or one eighth of a tank anyway.
01-29-2022, 10:01 PM | #40 |
A little pertinent info:
The car has a saddle tank. Right side has a pump with some valving and connections for evap/purge plus the liquid fuel line to the hp pump up front. There is a transfer line from the left side as well as a vent line. Both left and right side have fuel level sensors. The left side of the saddle gets drained first. The right side is full until your gauge in the cluster reads half a tank. At 1/4 tank, the right side is half full, the left is empty. Even at 1/8 fuel level the pump is sitting in a good bit of liquid. Not saying you should run it to empty, just that the tank is emptied asymmetrically. |
01-29-2022, 10:24 PM | #41 |
Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
While I’m working remotely my SS has been used for very short trips to grab lunch or coffee meaning a full tank would last me around 2 weeks… The problem with that is I get a habit of just getting on the road and getting what I want and forgetting that I need gas. I’ve found that needing to fill up LESS has actually put me MORE in danger of running out of gas because I’m in such a routine of not needing to stop for fuel that I literally subconsciously ignore the gauge and forget to stop for fuel.
01-29-2022, 10:27 PM | #42 | |
Indeed I was responding to a scenario when someone keeps driving the car 30-40-50 miles after the low fuel light comes on. I try to always fill up sooner than seeing this light.
