09-25-2015, 03:12 PM | #1 |
Drives: 2018 2SS Camaro Hot Wheels Edition Join Date: Sep 2015
Will the 6th Gen Camaro Be the Fastest Car You've Owned?
I currently drive the Tenth Generation 2014 Impala LS with a 2.5 L, 4-cyl. engine with 195 h.p. I would say the 0-60 time is about 8 or 9 sec. I'm probably way off though. There are specs. for the V-6 which is 0-60 in 6.8 sec. rated at 305 h.p.
So, stepping into a new 6th gen Camaro 2LT V-6 with a 0-60 time of 5.1 econds with the automatic tranny, 13.5 sec in the 1/4 mile and a 12% lbs/h.p. improvement over the 2015 model is a definite YES for me. This will be the FASTEST CAR that I will have the pleasure of driving the hell out of!
Zack46
2018 Camaro 2SS Orange Crush Hot Wheels Limited Edition Power Sunroof, 8 Speed Auto/Remote Start, NPP Exhaust Production Sequence Number 98 NEOCC Camaro Club Member Former Ride: 2016 Camaro 2LT RS V6 Hyper Blue Metallic |
09-25-2015, 03:18 PM | #2 |
Drives: 2016 F150 Join Date: May 2014
I'd say so.. If I do get it. Next up would be my Mustang and then 05 GTO. 10 cars under my belt so far. Whoops. From 1.7l to a 6.0. Need a 7.0.
09-25-2015, 03:28 PM | #3 |
Drives: Coupeless :( Join Date: Jan 2015
Yep. I've only had two cars so far. I had a Cobalt 2.2 (0-60 was about 3 days) for about 7 years, and I've had an Optima Turbo for the last 3 years (0-60 is about 6.5 sec).
09-25-2015, 03:36 PM | #4 |
Unleash the Beast!
Not at first, but once I am done. Yes.
Summit White 2SS delivered 12-11-2015
09-25-2015, 03:50 PM | #5 |
Faster than my '99 SS was, so definitely will be the fastest I've owned.
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
09-25-2015, 04:09 PM | #6 |
Drives: 2016 V6 RS Camaro 6MT Join Date: Aug 2015
Yes. And, I'm only getting the V6.
edit: I should add that I had 2 x 1995 Z28's for many years. The V6 should be slightly faster than the 4 gen LT1. Those cars were more than enough for me. I'd probably kill myself with a SS. Last edited by GTIanZ28; 09-25-2015 at 06:32 PM. |
09-25-2015, 04:26 PM | #7 |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
Yep!
2010 Camaro 1LT V6 (Sold. I will miss her!) |
09-25-2015, 04:40 PM | #8 |
Drives: 2016 Garnet Red Camaro 2SS Join Date: Jul 2015
I had a '98 SS, it was pretty quick for "only" 320 hp.
09-25-2015, 04:44 PM | #9 |
It definitely was. I managed 12.98 on my 1st time out with DRs. Never got to practice enough to get full use of them. I had previously run 13.0 on BFG KDW tires. This was all before I got the trans rebuilt and new stall but never made a pass with them before I sold it.
09-25-2015, 04:49 PM | #10 |
Drives: 1969 Corvair, 2018 Camaro T4 RS Join Date: Mar 2009
To answer the question, no, no matter which flavor of the 6th Gen is considered.
Laborsmith |
09-25-2015, 05:04 PM | #11 |
GM repeat offender...
Drives: 16 2SS Join Date: Dec 2014
Not even close... But for sure the COOLEST!
'16 2SS, Summit White. A8. MRC. NPP.
Ordered:09/03/15. Received 12/22/15 INCOMING: ‘22 ZL1, Satin Steel. A10. PDR. Ordered: 03/02/22. |
09-25-2015, 05:24 PM | #12 |
Drives: 2001 T/A, 2010 2SS/RS, 2006 Z06 Join Date: Apr 2009
No way. I had a much faster C6 Z06, and a 99 Z28 with a 408 stroker that was even faster than the Z06.
09-25-2015, 05:33 PM | #13 |
Bad Camaro
Drives: 2013 Camaro 2LT Convertible RS Join Date: Dec 2012
If I get a 2SS it would be the fastest car I've ever owned. I currently have a 2LT Camaro and its quick!
09-25-2015, 05:43 PM | #14 |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
Yep. Definitely faster than my '12 5.0.
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
