03-20-2023, 08:12 AM | #1 |
Mudguards/rockguards
Who makes the above that are actually molded
To the body and fit properly? (For ZL1) |
03-20-2023, 08:27 AM | #2 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
I don't believe that are any like you're referring to that I can think of. It's either ZL1 Addons or ACS
03-20-2023, 08:56 AM | #3 |
Drives: 2023 Camaro ZL1 2023 BMW X5 Join Date: Mar 2023
Just got my ZL1 last week and my ceramic coating rep told me I should apply protective film to areas where debris hits the body and/or buy rock guards. He advised that basically every 5th or 6th Gen Camaro he sees with no protection has pitted paint on the lower quarter panels, front and rear, from road debris. After exhaustive research on this topic, and totally against my financial conscience, I ordered the ACS Composites front and rear rock guards… my decision was heavily swayed by the folks on this forum that have them, highly recommend them and advise that they look OEM.
That all said, never thought I’d spend 400 bucks on mud flaps! |
03-20-2023, 09:22 AM | #4 |
Drives: '24 Camaro 2SS Conv. & '21Blazer Join Date: May 2011
I went with the ZL1 Addons a couple of weeks ago. They were about a $100 for the front and rear set. No drilling and can be installed without removing the wheels. I think they look good and should provide some protection.
'24 Camaro 2SS 6M Convertible
03-20-2023, 09:29 AM | #5 |
The only one that looks even remotely similar to OEM splash guards is the $400 ACS part. All others look like mudflaps, some much better than others, but they cost 4x less. Your call
03-20-2023, 09:38 AM | #6 |
with these things you can have aesthetics, or protection, but not both. (pretty much)
03-20-2023, 10:53 AM | #7 |
Drives: Camaro ZL1 Join Date: May 2020
ACS Sucks.....
03-20-2023, 10:58 AM | #8 |
NYTMARE23
Drives: Black 2023 Chevrolet ZL1 A10 Join Date: Oct 2022
No rock gaurds/mudflaps for me. I have PPF only and its been just fine. 3 guys I know with Camaros(2 other ZL1'S and one SS 1LE) only did PPF and they all have said they have ZERO rock chips/pitting on their paint. One of the ZL1 guys tracks his also. So to me, it appears that the rock gaurds/mudflaps aren't NEEDED. Plus, a sports car with mudflaps just looks wrong..
2023 A10 ZL1 "NYTMARE"
03-20-2023, 11:18 AM | #9 | |
Depending on the roads driven, the occasional rock may find its way to the rockers even with side skirts, but a thick PPF will probably block these indeed. I for one don't mind the way my Rokblokz guards look, their cut matches the car's lines, the front is wide enough, the rear extends all the way across 305 and 315 wide tires, and its edges are nicely outlined with a gloss black bead, so it's a "glorified mudflap" at the very least
03-20-2023, 11:38 AM | #10 |
Petro-sexual
I tolerate my ACS guards only because they're on the car. I can still sling tire goo on the sides of the car with them on, which, to me, means there's a good chance I could still get rocks flung up the side, too.
I still think PPF is a better option, but don't think it's cost effective, considering it's apparent life.
03-20-2023, 11:47 AM | #11 |
Use a water based tire shine, and wipe it on instead of spraying it on. Then you won't have that problem.
RUXIFEY Smoked LED Side Marker Lights / Black SS emblem on rear bumper / Blue SS vinyl overlay on front bumper emblem / Wildhammer Rear Dark Reflectors / Trim Illusion Gloss Black Door Handle Covers / eBay Black Fuel Door / Screaming Chicken Fender Hash Marks / Color-Matched G2 Caliper Paint RE Audio RFX10D4 10" Sub / Hand-made sub enclosure / Hifonics Zeus ZRX1200.1D amp / JL Audio LoC-22 line output converter / Sub Thump Plug N Play T-Harness With ANC Defeat Harness Kit My Camaro Journal |
03-20-2023, 03:04 PM | #12 |
Drives: 2022 Vivid Orange ZL1 Vert M6 Join Date: Jul 2017
I went with the rokblokz in the front. I modified the rokblokz for the rear (cut off the upper portion as it caused a twist. I have the ZL1 add on rears coming in today to try. I am not a fan of the ZL1 add on clip method for the front. The rokblokz have a good method for the front but the only issue is the cheap tab clip strips out very easily. Solution for that was a nut behind it with a machine screw.
03-20-2023, 03:40 PM | #13 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
FWIW, changing out the tires will pick up less rocks, too. Not a fix-all, but an improvement in what does get picked up and tossed at the bodywork. The SC3's pick up all manner of pebbles, even when cold.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
03-20-2023, 08:05 PM | #14 | |
Quick follow up: the ZL1 add ons rears fit very well. So my $.02 is rokblokz in the front and ZL1 add ons in the rear. If anyone is interested I have the modifications to the rokblokz is this video. It’s a bit long but goes through the trial, error and modifications. For the front you don’t need to add the nut but it think it gives a more positive clamp. https://youtu.be/t56kdzdSo1s |
