Old 08-15-2020, 07:44 PM   #1
eric sakai
Drives: 2015
Blue Velvet Metallic paint blending
Hi All:
I hit metal debry on freeway.
Have 4-deep scratches, each 4-inch long.
It’s on right door and rear fender.
Under the sun the metallic pops, and shade of blue changes at different angle.
Can body shop painter match the metallic and blue so it looks the same under the sun?
Aloha,
Eric
eric sakai is offline   Reply With Quote
Old 08-15-2020, 08:14 PM   #2
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
A good qualified painter should be able to. BTW, the “rear fender” is called the quarter panel.
Power is worthless without control. The 2nd protects the 1st.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 08-15-2020, 08:54 PM   #3
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
Agreed. Any experienced body specialist/painter should be able to get a near perfect match.
InFiD3ViL is offline   Reply With Quote
Old 08-15-2020, 08:56 PM   #4
fhrex
fhrex's Avatar
Drives: 2011 Camaro 2LT/RS
Sorry for you. I'd be heartbroken in your situation. Hope you get fixed good as new!
fhrex is offline   Reply With Quote
Old 08-16-2020, 08:20 AM   #5
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
Make sure the painter knows how to use "flop adjuster". The way the metalics. lay down on the panel is called "flop" and a properly trained painter can create a seamless repair.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
