10-31-2015, 12:24 PM | #1 |
Living Life in MPH.
Camaro 1le curb rash
I couldn't find a su forum for this so bare with me. I got curb rash on my 1le wheel last night by clipping a curb. It's very minor but I try my hardest to perfect and keep everything I own in pristine condition. I am wondering if anyone in Arizona has had any luck with ALLOY WHEEL REPAIR based in Tempe. For others on here, should I buy a new wheel or go through the dealership? any recommendations I am taking right now please. I will pay to have it perfect. Thanks guys.
10-31-2015, 12:44 PM | #2 |
Drives: 2018 ZL1 1LE, 1969 Nova SS 396 Join Date: Aug 2014
Similar thing happened with me right after I bought my ZL1, and I felt like a complete idiot but it happens.
If you google wheel repair places near you, you can find a decent shop that will do it for cheap. I got mine fixed for $125 and it looks brand new, no matter how hard you look your not going to find were it was fixed.
18 ZL1 1LE|M6|Nav|PDR|CF Hood|CF WING|CF Dash|Tow Hook| |
10-31-2015, 01:50 PM | #3 |
Drives: black and silver Join Date: Apr 2014
10-31-2015, 03:16 PM | #4 |
Living Life in MPH.
Has anyone near had luck with alloy wheel repair? They're wondering to paint the wheel the same color or powder coat the wheel the same color...?
10-31-2015, 03:23 PM | #5 |
Drives: 2012 ZL1 - #670 Join Date: Jun 2009
Hit it with a Sharpie until it gets repaired, helps take the sting out of it.
10-31-2015, 04:07 PM | #6 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
Hardly. It's the 800lb elephant in the garage. The Sharpie helps others not see it. The OP won't be fooled. Nor comforted. I can relate to the "disease." Hope you find a great repair shop, bro.
“I don’t want to belong to any club that would have me as a member.” - Groucho Marx
10-31-2015, 04:16 PM | #7 |
The same for me, i used my Dremel to sand it out then some matte paint. You can still see it though
10-31-2015, 06:46 PM | #8 |
Living Life in MPH.
The guy is asking if I want to paint or powder coat. I am wanting to know the paint code if anything?
10-31-2015, 07:57 PM | #9 |
Drives: '15 Camaro 1LS/M6 Join Date: Oct 2015
Powdercoat can fade and get milky due to UV exposure. Also, with powdercoating, it would be harder to touch up if you scrape it again. When the newness wears off and you're willing to accept a slightly less than perfect repair that is. Trust me, that will happen when you get that first rock chip, scratch or heaven forbid a nice dent on it.
I would try getting it painted instead. However, if the other wheels are still pristine, I'd just try to find a mint OEM painted wheel. I'm sure I am more OCD than you and that would be the only way I would be totally satisfied if I scraped one of my wheels. Been there and done that with the powdercoating and repainting jazz on other vehicles and it's never as good as the original OEM finish. |
10-31-2015, 08:34 PM | #10 |
Drives: 1969 Z28, 1982 Z28, 2014 SS/RS/1LE Join Date: Nov 2013
I had one worse than that. Some careful work with a sanding and polishing wheel on my Dremel smoothed it out. Then touched up with a couple layers of this...
http://www.foreinnovations.com/product_p/pen_black.htm After dry I used some good polishing compound and wax. You cannot see it unless you absolutely know it is there. |
10-31-2015, 09:18 PM | #11 |
Drives: 2010 2LT/RS Black/IOM Join Date: Feb 2011
I heard the zl1 wheels paint is really thin anyways. Might take the time to have them all painted.
ZL1 Factory Reproduction Wheels, Airaid CAI, MRT V 2.0 Axle Back Installed by PIE Customs, Painted IOM Rally Stripes, Bowties by Danny Taylor Louisville KY, IOM Engine Cover and Fusebox Cover by River City Creations and Lighting San Antonio TX.
10-31-2015, 09:23 PM | #12 |
Drives: RS Join Date: Jan 2013
Don't use a Sharpie, it will turn purple. Check out Dent Wizard, they have a location in Phoenix.
https://www.dentwizard.com/wheels.aspx |
10-31-2015, 09:40 PM | #13 |
Just be glad they're painted and not brushed aluminum. Those are a pain to blend correctly.
11-01-2015, 04:46 AM | #14 |
Drives: 2010 Camaro 2SS/RS LS3 Join Date: Oct 2013
A wheel repair place can fix it as others have said, what gets expensive is the powder coating, then having the tire remounted, I would have to guess you are looking at $300-$400 when all done, good luck
Hurst Short Throw Shifter, K&N CAI, SRP Racing Pedals, GM Performance Exhaust, GM GFX Package
Lakewood Strut Tower Brace, JBA Shorty Headers, JBA 8 MM Wires, Airaid TB Spacer, Phastek CAI Scoop, Washer Bottle Relocation Kit, Stainlees Steel Brake Lines, Brake Performance Slotted and Drilled Rotors, BMR Tunnel Brace, BMR Trailing Arms, BMR Subframe Connectors, Borla ATAK Muffelers, Z28 Wickerbill Spoiler, VTC, Bow Tie Delete, BMR Adjustable Front Swaybar, BMR End Link Kit, BMR Extreme Rear Anti-Roll Kit, Diablo I1000 "InTune" |
