TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > Engine | Exhaust | Bolt-On | Drivetrain Modifications
Old 07-20-2013, 08:50 PM   #1
SSmokey
Drives: 2012 Black ZL1 Camaro
Solid State Isolator ?
Hey guys I have only found 1 vendor selling this solid state isolator. Does anyone know other vendors selling them? Is there one that stands out more than the others?
SSmokey is offline   Reply With Quote
Old 07-20-2013, 09:22 PM   #2
DangerZL1
Drives: 2023 Black ZL1 Auto
I think everyone's selling the same isolator, so I'd go for the best price and choose a vendor who you plan on doing business with in the future. Are you referring to the solid coupler for the supercharger? LPE has been selling them for a while.
Old 07-20-2013, 09:39 PM   #3
SSmokey
Yes that is it
Old 07-24-2013, 02:24 PM   #4
wirebender
wirebender's Avatar
Drives: 2017 ZL1, A10, White, sunroof, nav
What is this? What is its purpose/advantage?
wirebender is offline   Reply With Quote
Old 07-24-2013, 03:20 PM   #5
DangerZL1
A lot of the ZL1s and CTSVs have a rattling noise that sounds like marbles in a can coming from the Eaton SC. The noise is caused by a spring on the OEM coupler that wears into the shaft of the SC. The noise is generally eliminated by using the solid coupler. It's a must when changing to a smaller upper pulley, since it costs less than $50, but would be a lot of work to change just to get rid of the noise.
Old 07-24-2013, 05:47 PM   #6
SC2150
Drives: 2012 Camaro RS, RX supercharged
All LSA engines use this same blower. The noise is from the (not very good designed) coupler/spring system and it makes noise that is annoying, and gets worth with miles.
Going with a solid coupler eliminates the noise, but there is no isolation between the drive pulley and the gearset so the life of the head unit is shortened by app 30% (direct from GM engineer).
There must be some shock dampening or all is transferred directly to the gears/rotors/shafts/bearings, and a solid coupler transfers all that shock but does eliminate the noise.
SC2150 is offline   Reply With Quote
Old 07-24-2013, 10:03 PM   #7
Matt @ FSP
Matt @ FSP's Avatar
Drives: 2011 Camaro SS
METCO Motorsports, LPE and I think KDi has an isolator also.
We've been installing the solid coupler/isolators for years now on the Eaton blowers. It is not just noise that you will experience when the isolator starts going, but you will see it show severe signs of wear. I have seen bad isolators on 1500 mile cars (as well as shaft wear), as I have seen them on higher mileage cars, and vice versa I've seen plenty of good ones still that we have changed because it is a must.
Here are some pictures of the wear on the shaft Shaft wear 1, Shaft wear 2.
Here is a media drawing released from GM in late 2012 that actually identifies a solid coupler being used in the LSA motors.. Unfortunately that has not happened yet. There were talks that the new supercharger kit part number 19301022 includes a solid isolator. I can neither verify nor deny that, so take that with a grain of internet salt rumors!
The very popular Eaton M62, M90, models that GM has used on various vehicles with the 3800 series motor (Grand Prix, etc.), 2.0L Ecotec Cobalt (M62 Eaton), does not have a torsional spring loaded coupler, as they have a solid one piece coupler.
Below is a picture of the Eaton solid coupler used in GM applications in the past.
Matt @ FSP is offline   Reply With Quote
Old 07-25-2013, 07:35 AM   #8
Modern07
Mid-Florida Camaro Club
Modern07's Avatar
Drives: 2019 ZL1 on Order
Good Info Matt - and that's exactly why I'll be putting one on mine!
Modern07 is offline   Reply With Quote
Old 07-25-2013, 11:17 AM   #9
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
Yup, CTS-V owners have been doing the solid isolator mod for years now. I'll be doing it at some point.
BaylorCamaro is offline   Reply With Quote
Old 07-26-2013, 08:26 PM   #10
mmarx82
mmarx82's Avatar
Drives: '12 ZL1 #1609
I've had mine for awhile, still yet to do this mod though, shame on me...
Life is too short to drive cars that suck.
My build Thread
mmarx82 is offline   Reply With Quote
Old 07-30-2013, 11:45 AM   #11
bumblebeecamaro
Car Lover By Nature
Drives: 2016 Hyper Blue Metallic SS
okay, so do I replace the coupler and decrease my blower's life span by 30% (according to Tracy's post) or do I leave it alone and wait for the ticking timebomb to let go as in my blower taking a dump?
bumblebeecamaro is offline   Reply With Quote
Old 08-01-2013, 11:36 AM   #12
joes407
joes407's Avatar
Drives: 2014 ZL1m6 red hot #569
at least with the latter g.m will fix it under warranty. keep in mind my whole supercharger had to be replaced at about 10k miles. dealer said new s/c had different design so wouldn't happen again but im just starting to hear the noise on occasion creeping in. I know soon there will be another s/c needing warrantied so I have opted to wait on the coupler just in case. if that happens I may try a solid coupler.
joes407 is offline   Reply With Quote
Old 08-01-2013, 07:02 PM   #13
Modern07
Modern07's Avatar
These are the pics of the damage caused to mine after 9,400 miles
http://www.camaro5.com/forums/showthread.php?t=310588
I'd replace it!
Old 08-01-2013, 07:10 PM   #14
joes407
joes407's Avatar
[QUOTE=Modern07;6847633]These are the pics of the damage caused to mine after 9,400 miles
so lets say he replaces it and then finds out the 30% loss in s/c life is true. then what? you must remember the car has been out for a year so we really should know what kind of miles people have put on the solid isolators without issue. I believe I have one of the higher mileage '12's on this site so im real curious about longevity of the solid one. as we speak there is a shop working on a solid isolator for a chevy dealer that does not rattle the super charger to death.
