Old 07-02-2013, 01:01 PM   #1
lincoln361
lincoln361's Avatar
Drives: 2011 Camaro SS/RS
Smile Did i do this right?
Yes, I have the hoses on their like that, just to show you how I am running the hoses lol ha ha. Doesn't look too pretty right now. I just want some confirmation before I start running the hoses to know I got it done correctly. I was looking back and some threads and I think I got them backwards. If you guys can help me out, that would be great. Thanks in advance..
SLP TVS 2300- 1 7/8 LG Headers- RDS NX Plate- 75 Shot- No Cats- SLP Loudmouth 2- NW102- 3.8 Pulley- OD Cog drive-12lbs boost-FIC 80# injectors-ZL1 Fuel Pump- RotoFab CAI- Apex CAI Scoop- Pat G Tune- Weld RTS drag pack- BMR Trailing Arms- BMR 1'' Drop Springs-BMR Lower Control Arms- BMR Toe Rods- BMR Rear Cradle Bushings- BMR Upper Control Arm Bushings- BMR Extreme Anti- Rollbar- Hotchkis Subframe Brace- Prosport Evo Boost & F/A Ratio
lincoln361 is offline   Reply With Quote
Old 07-02-2013, 01:16 PM   #2
forklord
forklord's Avatar
Drives: 2010 2SS
looks right to me. i have my cheap ebay one like that. in the same location too. got a monster rx sitting here. scared to use it cuz theres metal shavings in one side. and it wont fit anywhere lol...
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
forklord is offline   Reply With Quote
Old 07-08-2013, 01:56 PM   #3
lincoln361
lincoln361's Avatar
I went to the track a couple of times with the lines lined up like this. I think only one drop came out of it. Not sure what to think
Old 07-08-2013, 02:00 PM   #4
lincoln361
lincoln361's Avatar
http://www.camaro5.com/forums/showth...ighlight=catch
This member i believe has is his catch can lines lined up different from mine. Can somebody tell me which way they go.
Old 07-09-2013, 03:39 PM   #5
lincoln361
lincoln361's Avatar
Anybody????
Old 07-09-2013, 04:33 PM   #6
bmbbl be
bmbbl be's Avatar
Drives: 2010 CAMARO SS
its right ,,,,from driver side rear to center and from blower to other line,,,, you wont get a lot of oil with a rx can,,,, he uses a check valve which is highly needed on forced induction...
bmbbl be is offline   Reply With Quote
Old 07-11-2013, 09:07 PM   #7
pdiddy
Drives: 2011 2SS
I have mine exactly like yours in the picture and I talked with Rx about it you are gtg
2011 2SS,fti th400, ECS 1500, Flex Fuel, Boost built 376, squash fuel system
pdiddy is offline   Reply With Quote
Old 07-11-2013, 09:19 PM   #8
newagemuscle
Philippians 4:13
newagemuscle's Avatar
Drives: SLP Supercharged LS3
So you decided to go with a catch can too. I just put mine on last week to. I went with the Elite.
newagemuscle is offline   Reply With Quote
Old 07-23-2013, 10:05 PM   #9
lincoln361
lincoln361's Avatar
Let me know if you are catching alot of oil. I really have not got anything out. I might have to go that route
Old 07-24-2013, 08:38 AM   #10
SC2150
Drives: 2012 Camaro RS, RX supercharged
The amount of oil is directly related to how well your rings sealed....poor seal equals a lot of oil, good seal very little.
Also, on the RX can (or MN which uses the same drain valve) make sure the threads are all the way our extended for closed, in retracted for open.
SC2150 is offline   Reply With Quote
Old 07-24-2013, 03:20 PM   #11
lincoln361
lincoln361's Avatar
Thanks for the info. I will double check everything to make sure I have it on properly. I don't believe I have the threaded part right. If not oil would be filled in the plastic drain line right?
