TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
Old 04-28-2012, 05:49 PM   #29
Rogan
No Pain No Gain
Rogan's Avatar
Drives: Yellow 5th Gen 2SS RS
Originally Posted by carls2010 View Post
ill try, but it seems it wouldnt be battery problem as when i release the lock button on dash it does NOT cycle the lock's like it suppose to ???[as posted] -- like it is in program mode ????, Seems like its not entering program mode ?? ------------Just swaped batterys, -not battery
Maybe someone else will come in and give advice. Either the FOB has and issue going into program mode, something is locked on your car preventing it from going into program mode or something in the steps is not being done correctly. The steps are pretty straightforward, so I thinking its something outside of the steps.
I'm sure someone else will come in an advise you. You might be better off starting a new thread in the main thread area and pointing back to this one. Something like NEED HELP and pointing to this thread could probably get the traffic you need to the thread for the right person to eventually come in and tell you what you need to do.
2010 2SS/RS/L99 - Headers/CAI/SWAYs/CoilOvers/Tune/Steel Braided Brake Lines/Frozen Slotted Rotors
Rogan is offline   Reply With Quote
Old 04-28-2012, 05:51 PM   #30
carls2010
carls2010's Avatar
Drives: 2006 Corvette
k, ill try.-thanks
carls2010 is offline   Reply With Quote
Old 04-28-2012, 09:53 PM   #31
Rogan
No Pain No Gain
Rogan's Avatar
k, ill try.-thanks
no problem....
you'll probably get more replies during the week.. weekend folks are out enjoying the weather.
Old 04-29-2012, 11:51 AM   #32
awfarley
awfarley's Avatar
Drives: 2011 5.7L Tundra Double-Cab X-SP
Originally Posted by hatter69 View Post
Key Fob Fix
Misplaced one of my keys and never found it. Ordered a new one ($50). Dealer wanted 1 hour labor ($50) to reprogram or sync the buttons to my car. Found the below fix online and 2 minutes time I was done!
April 15th, 2010 at 4:33 pm, Andrew Hughes Says:
1. Close all vehicle doors.
2. Insert the key into the ignition.
3. Hold down the power UNLOCK button on the driver’s door panel(CENTER FOR US CAMARO OWNERS)-continue to hold
down until instructed to release in step 9.
4. Perform steps 5 through 8 in fairly rapid succession.
5. Turn the ignition switch to the ON position (as far as you can go without starting the
engine).
6. Turn the ignition switch to the OFF position.
7. Turn the ignition switch to the ON position.
8. Turn the ignition switch to the OFF position.
9. Release the power unlock button on the door panel. The vehicle will lock and unlock
the doors automatically.
10. Hold down the LOCK and UNLOCK buttons on the transmitter simultaneously until
the door locks and unlocks.
This step may take up to 30 seconds.
11. Repeat step 10 NOW for each additional transmitter (including any existing
transmitters).
12. Turn the ignition switch to the ON position in order to exit the transmitter programming
mode.
Hatter69 2010 LT1 Black #366
Sounds like a button punch code for the Sega Genesis. Once you finish this your car should transform into Bumble Bee.
Very cool thread though seriously.
awfarley is offline   Reply With Quote
Old 06-06-2012, 01:16 PM   #33
montyhp
montyhp's Avatar
Drives: 2011 2LT/RS Red Jewel w/Beige
key fob problem
I bought a key fob from Ebay and had it cut by a local locksmith. So far so good. Then I did the program steps from this thread, old key on & off, new key on & off. now the key fob will unlock and lock doors but will not open trunk or start car. Anyone else run into this? Is this a faulty fob or something I am doing wrong?
montyhp is offline   Reply With Quote
Old 07-04-2012, 03:41 PM   #34
talalhz
talalhz's Avatar
Drives: 2011 Camaro 2SS 6M
It works !!!!!!!!!!!!!!!!!!!!!!
Originally Posted by jshaf View Post
or you can put one of your origional keys in the ignition and turn to the on position, then remove it, put your new unprogrammed key in the same ignition and turn it to the on position and wait to hear it beep and display "third key remembered" or some thing like that on the center display. that is how I programmed my ordered key. works just like the one that came with my car.
IT WORKED FOR ME ! IT TOOK 10 SECONDS TO PROGRAM THE KEY ! THE LOCK AND UNLOCK BOTTONS WORK ON THE REMOTE, AND THE CAR STARS. PERFECT ALSO!
I bought the key online with out giving them the VIN number. I had it cut at a locksmith and programed it my self this way
THIS IS THE WAY TO DO IT.
'11 2SS M6 inferno orange interior. Bone stock
Previus vehicles:
91 Cressida |96 Toyots T100 4x4 | 00 Lexus GS300 (Aristo) 2JZGE | 01 Lexus GS300 (Aristo) 2JZGE | 94 Supra Turbo 2JZ-GTE (JZ80) MT | 03 Evolution VIII 8 4G63 (CT9A) | 04 Subaru Impreza WRX STi |05 Evolution VIII MR 4G63 (CT9A) | 05 Cadillac CTS-V (LS6) | 06 Lexus IS350 | 09 Evolution X 10 (4B11) | 09 FJ Cruiser TRD | 09 Pathfinder V8 5.6L | 11 LandCruiser (LC100) | 11 Camaro 2SS LS3 | COMING SOON: 13 Camaro ZL1
talalhz is offline   Reply With Quote
Old 07-04-2012, 04:53 PM   #35
carls2010
carls2010's Avatar
I Have two used, like new fobs for sale....yOU WOULD JUST NEED TO GET THE KEY PART TO PUT ON THE FOB, AS THIER ALREADY CUT....
Old 02-08-2014, 08:53 PM   #36
Camaroshark
Drives: 2010 Camaro 2SS/RS RJT, 6speed
I have to punch this thread to the top. I continue to be amazed at how fantastic this little Camaro community is.
My key fob, well one of the buttons fell out / broke out. I ordered a blank using the links on here (to ebay) for $27. I received the blank in the mail yesterday. I started trying to take it apart and that was a bit of a nightmare as I think they are glued.
So I found this thread. I used the information to punch the pin out and swap the key for the key in the blank and then used the second key to my car to program the blank using the instructions on this thread.
For a whopping $27 I have a brand new Key fob and I didn't need to waste a half day at the dealer or pay absurd prices to do in about 10 seconds what I did moments ago.
Thank you guys!!!!!!
2010 Camaro 2SS/RS, LS3 - 6 speed. Mods, Magnaflow exhaust with resonator delete. ******** 12" stealth box subwoofer kit, Kicker 400 mono amp, JL XD 400/4 amp.
Camaroshark is offline   Reply With Quote
Old 02-24-2014, 04:58 PM   #37
alberto216@hotmail.es
Drives: red
hi, my camaro 2010 rs key was stolen, and a frind give me a new one, but this was used and programing for his car, you know how can i reprogram the key?
alberto216@hotmail.es is offline   Reply With Quote
Old 02-24-2014, 07:21 PM   #38
Rogan
No Pain No Gain
Rogan's Avatar
same way you would if you got a new key. the key gets programmed to the car. follow the instructions and you should see it working.
Old 03-12-2014, 12:08 PM   #39
cgreer72
cgreer72's Avatar
Drives: '13 1LT RS
Has anyone attempted this on a '13?
cgreer72 is offline   Reply With Quote
Old 07-28-2014, 05:00 PM   #40
SKFOOTER
Drives: 2010 CHEVROLET CAMARO 2LT SIM
I lost my spare key fob to my 2010 Chevrolet Camaro LT RS and called my dealer for a quote. He said it would have to be ordered from the parts warehouse pre-cut and would cost me $140. That is ridiculous. Can I order a new key fob from GM Parts Warehouse and have a locksmith laser cut it???
SKFOOTER is offline   Reply With Quote
Old 07-28-2014, 05:48 PM   #41
carls2010
carls2010's Avatar
key/fob
I havent been on in awhile, but when i did have my 2010 S.S., I needed a new fob and key and I found locally a shop that stocked the fob and key and he cut it and programed it all for 60.00 plus tax.
What dealer gets is a rip off, and there is no laser cutting on the key..
Any key/lock place thats has the machine , will tell you that is what gm calls it laser cut, but shops have cutters to do it..
If ya find a local place that sells key and fob's [ yes you can get them seperate ]
I would be more than happy to sell my fob;s as i have no use for them..
The place that does them here is called , Glad security.. and im near syracuse N.Y.
here is link.
http://www.gladdsecurity.com/
Old 07-28-2014, 05:51 PM   #42
carls2010
carls2010's Avatar
Glad security near syracuse ny, sells and cuts keys. -And no is not laser.
Cut by machine..
I had orig equip fob programed and key cut for 60.00 plus tax.
Here is link to thier sight.- I used them, as i work for chrysler and need a place to cut thos type of key/fob Thier called side winder keys
Remote Start System Installation – Need Assistance Railcar Camaro DIY & HOW-TO instructions & discussions 27 12-09-2013 04:51 PM
Key Fob Mod LED - My First Mod... Buhmblbe Camaro DIY & HOW-TO instructions & discussions 15 12-07-2010 05:23 PM
Remote Key Fob Design Fault GNVenom Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 54 06-01-2010 10:42 PM
Key fob reprogramable? Jason@JacFab 5th Gen Camaro SS LS LT General Discussions 9 05-18-2010 07:07 PM
Problem with Key Fob anyone? ffrcobra_65 5th Gen Camaro SS LS LT General Discussions 8 12-12-2009 01:45 PM
