Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
Old 04-13-2017, 06:19 PM   #71
Scotty D
Drives: 2014 1le 1SS CRMT
Ok cool thanks
Scotty D is offline   Reply With Quote
Old 12-11-2017, 10:20 AM   #72
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
bump.
2SSRS@Gen5diy is offline   Reply With Quote
Old 10-27-2019, 05:38 PM   #73
paulsandhu
paulsandhu's Avatar
Drives: 2010 Camaro 2SS/RS
I got the harness from Gen5Diy but I am lost as to where to connect it to correctly. I have it connected to the HUD projector and the switch, but I can't seem to find where the 3rd connection that would draw power from the car connects to.
any help?
GHOST · 2SSRS
Order Date: March 28, 2009 // DoB: June 19, 2009 // Arrival Date: July 2, 2009
Current Modifications:
  • Hurst Comp HardDrive Stick Kit
  • K&N Blackhawk CAI
  • Anvil Carbon Fiber Notch Spoiler
  • Ceramic Coated Satin Black Wrap
paulsandhu is offline   Reply With Quote
Old 10-28-2019, 01:20 PM   #74
Baldman
EMERALD COAST CAMAROS
Baldman's Avatar
Drives: None
any help?
Give gen5Diy a call or send a PM. they are very good at helping people out.
Baldman is offline   Reply With Quote
Old 10-29-2019, 06:15 AM   #75
Pagliaro
RIP Betsy ( Vitara )
Pagliaro's Avatar
Drives: '11 SGM 1LT/RS
Send a message via AIM to Pagliaro Send a message via MSN to Pagliaro Send a message via Yahoo to Pagliaro
I believe it connects to the 4 gauge cluster
First retrofitted 2014 mylink.
Pagliaro is offline   Reply With Quote
Old 11-28-2019, 12:18 PM   #76
KenBaker
Drives: 2010 Camaro SS
Could this be done simply by pulling the Windshield? My car needs a Windshield and I thought I could have them pull it and come back when this has been completed
KenBaker is offline   Reply With Quote
Old 01-15-2022, 05:56 PM   #77
Tm zaman
Drives: Camaro
Originally Posted by 2SSRS@Gen5diy View Post
26:This is for M6 cars only we have our receiver for the remotes in the dash and you need to disconnect it, its to the right and behind the instrument gauges, its on the bottom of the top of the dash and is 2'x5" long.
27: its time for some help to pull out the dash, you need to work it around the ignition switch and pull the two sides at the same time don't let one side get in-front of the other, and take it out set it up on some towels,
28: Now that you have it on the towels you need to put it on its back and remove the 5-7mm bolts that hold the ac duct.)
29: now its time to cut the dash for the HUD head unit and switch,
Insert the HUD trim and start setting buy pushing in the 5 clips in the dash to hold the HUD in place then use the screws to hold them in, now put back the ac duct.
30: Now the last part's run your new HUD wiring harness behind the dash now is the time to do so, all you do is connect it to the 4 pack connector and run it with the wires coming from the main wiring off the dash, ONE more time do not forget the sting on that connecter that comes from the defroster vent, its time to stat putting it all back, try to do it in the opposite order you removed it.
On 29: why you cut ur dashboard
Tm zaman is offline   Reply With Quote
Old 01-16-2022, 10:46 AM   #78
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
because the HUD is in the dash and reflects up onto the windshield. It's cut the dash or get a dash out of a HUD equipped car.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes.
CamaroCracka is offline   Reply With Quote
Old 12-14-2023, 11:56 AM   #79
LSX_Tony
Drives: 2013 ZL1 1997 ZR2
Hey guys,
Old post I know…I recentlybought a 13 ZL1 and I’m just wondering if it’s possible to remove an existing HUD through the gauge cluster opening. I’d like to upgrade my HUD to the colour version. I’m not against pulling the dash but obviously would avoid it if possible.
Thanks in advance!
LSX_Tony is offline   Reply With Quote
Old 12-14-2023, 02:02 PM   #80
Coz3z3
Drives: 2015 Z/28, 2015 1LE
Originally Posted by LSX_Tony View Post
Hey guys,
Thanks in advance!
No it's not. The screws that hold it, screw up into the dash. I think the screw at the front driver side would almost be inaccessible as well if I remember right.
Coz3z3 is offline   Reply With Quote
CAMARO WIKI Tran Wiki 66 04-22-2024 11:41 AM
Gran Turismo 5... No Camaro? 5thGenOwner 5th Gen Camaro SS LS LT General Discussions 111 12-06-2011 10:06 AM
GM memo to dealers Moose 5th Gen Camaro SS LS LT General Discussions 41 02-04-2010 07:33 PM
