03-08-2011, 06:52 PM | #29 |
Camaro Lover
Drives: 2014 GMC Sierra 5.3L Join Date: Feb 2010
precicsly they are quick connects / quick disconnects.
No Camaro right now. But I'll be back in one in a few years.
03-09-2011, 06:52 AM | #30 | |
Drives: Love the one you're with Join Date: Sep 2009
04-25-2011, 07:56 PM | #31 | |
Florida C5
Drives: 2010 Camaro 2SS Vortech L99 IOM Join Date: Jul 2009
thanks in advance
Ordered 11/08/08....Del. 08/05/2009 Loving every minute of it! Don't hate me because i'm Pretty....
04-25-2011, 08:16 PM | #32 |
Blown Cool Breeze
Drives: 2011 Black on Black 2SS M6 Join Date: Jul 2010
Use 3/4" hose on everything.
Sounds wierd but works perfectly. You will see what I mean when you install them.
Had a 2010 IBM 2SS M6 Enjoy life.Think of all the women on the Titanic who passed up dessert. |
04-25-2011, 08:51 PM | #33 |
Drives: '69 SS Convertible Join Date: May 2009
Actually from what I remember it's both 5/8 and 3/4 on both hoses. In other words looking at connection points on the firewall the one that's 5/8 will go to the one that's 3/4 on the waterpump. Same in reverse on the other side.
If you order the hoses listed in the first thread they'll install perfectly (with a little length trimmed off one hose).
-2010 Camaro 2SS | M6 | VR w/White Stripes | 1 3/4" KOOKS - 3" Magnaflow | LPE 3.91 gears | ADM tuned | Halltech w/ADM Scoop | Spohn/BMR Trailing Arm/Toe Rod | BC Coilovers| Pedders FE4 ZL1 swaybars | Cradle/Diff/Radius Rod bushings | VMax TB | Morimoto Projectors | MGW shifter | Red Calipers
Build Journal |
04-25-2011, 09:08 PM | #34 | |
Blown Cool Breeze
I did not use the pre-formed hoses,just standard 3/4" heater hose from Napa. The larger fitting on the water pump is actually bigger than 3/4" thus requiering a slight bulge to fit over. The larger fitting at the fire wall fit the 3/4" hose perfectly. The smaller fitting at the firewall fit just ever so slightly loose with the 3/4" The smaller fitting at the water pump was easy loose. I used worm clamps everywhere. Kinda wierd if you ask me
04-25-2011, 09:12 PM | #35 |
Yes it is weird and your method of using 3/4" hose will work as well. I've heard of some people doing it with only the 3/4" as well. One side being pretty tight to go on and the other loose but with a tightened down clamp.
The ones I got off Amazon that are listed in the initial post already come with the slight buldge where need though. Makes it easy to deal with.
Build Journal |
04-25-2011, 09:15 PM | #36 | |
Blown Cool Breeze
I was going to use standard 5/8" hose on the firewall side but later decided against it. It was going to take way to much force to get it on there and there was no way it was going to fit over the larger water pump fitting. Again,the pre-formed hose may not be an issue.
04-25-2011, 10:53 PM | #37 |
Florida C5
Ok, now I'm confused..........
Will order the two hoses off Amazon and see where it leads. Thanks Guys
04-26-2011, 09:35 AM | #38 | |
Get the hoses off of Amazon and you'll be good. Hardest part is getting the hoses off the firewall because they are stuck on there pretty good and there's not alot of room to get your hand up in there.
Build Journal |
04-26-2011, 08:14 PM | #39 |
I got my hoses from Napa. They were cross referenced from the Autozone part numbers through the Dayco website. In fast, they are Dayco hoses. They are 5/8" hoses with a 3/4" flare on one end, the ends being opposite for each hose. They needed slight trimming to make them the same length just like others stated. They worked out great and fit perfectly.
06-15-2011, 04:46 AM | #40 |
Drives: 2010 2ss rs sim camaro Join Date: Mar 2011
Livernois motorsports has a hose relocation kit for sale on their website
06-15-2011, 09:43 AM | #41 |
I couldn't find it but I'm willing to bet it's alot more than $35.
Build Journal |
06-15-2011, 11:16 AM | #42 |
In The Circle
Drives: 2010 Camaro 2SSRS IOM M6 Join Date: May 2009
Nice work! Certianly look's to be a good option and cost saver.
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
ReRoute of Heater hoses w/ pics | GMRULZ | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 92 | 09-18-2011 07:15 PM |
Can V8 be too much car? | tronic | 5th Gen Camaro SS LS LT General Discussions | 86 | 07-30-2010 09:10 PM |
Hose relocation kit | brooks35 | V8 Bolt-Ons & Tunes | 1 | 05-24-2010 10:00 PM |
TSB on Belt? | Screaminz2002 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 34 | 02-19-2010 07:28 AM |
Hose & Cable Catchers At ProperAutoCare.com | Angelo@Autopia | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 2 | 02-02-2010 03:05 PM |
