Old 08-21-2019, 10:56 AM   #29
6spdhyperblue
Drives: 6th gen
I just did this again this morning. It’s not great as you don’t get enough dirty fluid out of the clutch. I’m gonna have to up the frequency and just do outside bleeders. Don’t even need to pull the wheels. The clutch has a noticeable improvement even doing it this way. The big bottle of Lucas dot 3 synthetic quarterly. Ftw
Old 08-21-2019, 02:03 PM   #30
FollowMyLine
Driver for Hire
FollowMyLine's Avatar
Drives: 22 Camaro 2SS 1LE M6
FWIW, I had missed an inside bleeder when doing a flush a couple years ago, and ended up with a ton of air in my lines. Drive about 400 miles like that and needed to stop at a shop for an “emergency bleed” that took care of the air. I would recommend doing both bleeder valves and not just the outside.
Luan Zeqollari
2022 Camaro SS 1LE M6 - Wild Cherry Tintcoat - Delivered 9/20/21
2018 Camaro SS 1LE - Hyper Blue Metallic - RIP 6/6/20
YouTube Channel
FollowMyLine is offline   Reply With Quote
Old 08-21-2019, 02:06 PM   #31
6spdhyperblue
Drives: 6th gen
I did the inside last time. Why would I need to bleed the inside if I’m not introducing air into the lines? I’m doing it mainly to get fresh fluid to the slave cylinder. What method do you use to bleed?
Old 08-21-2019, 02:44 PM   #32
FollowMyLine
Driver for Hire
Just precautionary. Anytime you crack a bleeder valve you run the risk of getting air in the line. Just giving you a personal experience scenario. You don’t NEED to.
Luan Zeqollari
YouTube Channel
Old 08-21-2019, 04:44 PM   #33
6spdhyperblue
Drives: 6th gen
I appreciate it, I haven’t done it with just the outside bleeders before. Did you do the two man method. Open, Brake pedal down close, repeat? I def don’t want to deal with getting stranded
Old 08-21-2019, 08:02 PM   #34
FollowMyLine
Driver for Hire
When that happened, yes I did. I’ve since switched to a single person method using a catch bottle with a 1-way check valve. I can do all 4 corners now in about 40 minutes, once the car is up and tires are off.
Luan Zeqollari
YouTube Channel
Old 04-25-2024, 02:50 PM   #35
sleepys4
Drives: CT5 BW
Originally Posted by travislambert View Post
I fabricated a custom cap for the clutch/brake fluid reservoir with a hookup for a vacuum pump. Then I just let the vacuum pump do the work.
I had to pump the clutch a couple times and I also gave the inline clutch valve a little shake (just above the clutch pedal). The air came right out.
(I'm thinking the GM tech manual is where I got the idea. If I remember correctly it says to hook a vacuum pump to the reservoir.)
How much vacuum did you pull? Afterwards did you have to re bleed the whole system. Trying to figure out how this works.
Thanks,
jordan
sleepys4 is offline   Reply With Quote
