09-23-2015, 12:17 PM | #15 | |
Drives: 4 Wheels Join Date: May 2015
https://media.ford.com/content/dam/f...tang_Specs.pdf If the recommended fuel is 87, then that is all you need. If the LT1 says recommended premium (91/93), then that is what you need to run because that is what they have set up everything for. I don't have the LT1 or engine specs on them. Obviously you shouldn't run 87 in a engine that has a recommended of 91. Im going to assume that the SS is going to recommend/require premium because the Fuel.gov tests are running it for the Corvette. They only run the required fuel for these tests. http://www.fueleconomy.gov/feg/Power...te&srchtyp=ymm |
09-23-2015, 01:15 PM | #16 |
Drives: 2013 Hyundai Genesis Coupe GT Join Date: Apr 2008
Is there any advantage or power boost to running premium in the V6? My Genesis Coupe is only a 4HP difference.
09-23-2015, 01:26 PM | #17 | |
Drives: 2016 Garnet Red Camaro 2SS Join Date: Jul 2015
09-23-2015, 01:36 PM | #18 |
Drives: 11 F150 EB/13 Sonic RS/15 Z06 Join Date: Sep 2010
We saw about 5 RWHP on the old LLT. Tune it and you will see more than that though.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread |
09-23-2015, 01:42 PM | #19 | |
Curious to know what the V6 is going to recommend. I hope 87. It's actually not a dumb question. Lots of idiots are parted with their $$$ by running premium fuels when they don't need to. |
09-23-2015, 02:56 PM | #20 |
Drives: 2015 Tiger XCX,2016 Camaro 1SS,LBZ! Join Date: Sep 2015
Not a stupid question but not sure why no one talked about compression ratio. This is the main determining factor for fuel octane. Timing and efficiency of head design etc. obviously plays a huge part as well. If I am not mistaking the camaro is running a 11:5 to 1 compression ratio this is definitely premium gas. If it were not for the knock sensors we would not see this compression in a car engine. This engine is going to like 93 octane the best. Has to be able to run 91 because of California.
On a side note the higher the octane does not produce more power. It just retards the flame when the gas ignites. Technically 87 octane has a higher burning temperature or BTU then 93. I feel all 3 engines will prefer premium over 87. We are talking about high efficiency high compression engines. Also you can get away with lower octane fuel now a days but your gas mileage will suffer. Why bother running the wrong fuel? Example Nissan in my opinion for years produced the most efficient v6 production car engines in the world for years. Notice a huge difference between 87 and 93 when you do your mpg's. |
09-23-2015, 02:59 PM | #21 |
V6 should be 87...I have the current 3.6 in my SRX, and it is 87 only, so I am sure the same for the new V6.
09-23-2015, 03:10 PM | #22 |
Drives: 1969 Corvair, 2018 Camaro T4 RS Join Date: Mar 2009
I recall the ATS 2.0T recommends using premium and the 3.6 using regular.
But those are Cadillac installs and maybe Chevy is using something different. Laborsmith |
09-23-2015, 03:17 PM | #23 |
Destroyed by flooding
Drives: Wife's car Join Date: Mar 2014
In my owners manual for an L99 or LS3, use 91 or higher octane. Regular 87 octane can be used, but acceleration and fuel economy will be reduced, and an audible knocking noise may be heard. If this occurs, get 91 octane ASAP. Otherwise, engine could be damaged.
09-23-2015, 03:34 PM | #24 | |
09-23-2015, 03:34 PM | #25 | |
Drives: Current Camaro-less Join Date: Jul 2014
You speak incorrectly sir. The LT1 is rated at 91 octane. Just because it can run 87 or 89 doesn't mean you should, it's more so intended to get you home if you can only get 87. |
09-23-2015, 03:46 PM | #26 | |
Yes you are right DI has changed some of the variables and why we can now see a 12.5 to 1 compression on 93 or pump gas. The V6 is going to be regular fuel just looked it up. Compression ratio: 9.5:1 for 2016 chevrolet camaro v6. |
09-23-2015, 03:49 PM | #27 |
That's the CR for the LTG 4T. The LGX is still 11.5:1.
09-23-2015, 03:50 PM | #28 | ||
Like I said, if the LT1 is rated/designed to run at 91 and has a recommended fuel of 91, then that is what it should be put in it baseline. It CAN run on 87 in emergencies according to the Corvette manual. The 87 is only there in case of no available other fuel (like you run out of gas or gas station only has one type). It will get by but you need to get back to the higher octane ASAP or risk damaging the engine. The same applies to Audi engines that are designed to run on 91. You CAN put 87 in there but only in emergencies. That is a big difference in what I linked about the Mustang engines. All 3 are recommended for 87. You will not hurt the T4, V6 or V8 engine in a Mustang running 87 EVER. There are lots on the M6G forum telling people they need to run 91 in their V8 or risk engine damage which is entirely a load of crapola. Quote:
Use regular unleaded gasoline meeting ASTM pecification D4814 with a posted octane rating of 87 or higher. Do not use gasoline with an octane rating below 87, as it may cause engine damage and will lower fuel economy.Just found this for the LT1/Corvette. So the SS will require 91. Add up the extra fuel costs. If equipped with the LT1 engine, use premium unleaded gasoline meeting ASTM specification D4814 with a posted octane rating of 91 or higher. Last edited by VF-22; 09-23-2015 at 04:01 PM. |
