Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 07-25-2015, 01:24 PM   #1
ADM PERFORMANCE
Drives: Anything I want
Electric Power Assist Steering Problems List Grows
Just wanted to update what I have been monitoring on ELECTRIC POWER ASSIST STEERING ISSUES with 2012-2015 CAMAROS.
A true fix needs to happen before more people die.
http://www.usatoday.com/story/money/...?showmenu=true
EPAS PROBLEMS IN CAMAROS
Post and Threads
1.http://www.camaro5.com/forums/showthread.php?t=368931
2.http://www.camaro5.com/forums/showthread.php?t=367987
3.http://www.camaro5.com/forums/showthread.php?t=402656
4.http://www.camaro5.com/forums/showthread.php?t=397829
5.http://www.camaro5.com/forums/showth...light=steering
6. http://www.camaro5.com/forums/showth...light=steering
7.http://www.camaro5.com/forums/showth...light=steering
8.http://www.camaro5.com/forums/showth...light=steering
9.http://www.camaro5.com/forums/showth...=225187&page=4
INFOMATION:
Service Information
2012 Chevrolet Camaro | Camaro VIN F Service Manual | Document ID: 2831254
#PIC5643A: PQC Part Restriction - Electronic Power Steering (EPS) Service Steering Message Displayed And Increased Steering Effort - (Apr 16, 2012)
Subject:
Models:2012 Chevrolet Camaro ZL1
This PI was superseded to update department contact information. Please discard PIC5643.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
The DIC may display "Service Steering" in combination with an increase in steering effort and standard diagnostics may lead to steering gear replacement. As of 03/30/2012 Electronic Power Steering P/N 22848599 has been placed on restriction through PQC. This part restriction will allow Engineering to evaluate the fault while the steering gear is in the vehicle and prior to any repairs.
Recommendation/Instructions:
Important: Do not perform a Clear DTCs function.
Retrieve any stored DTC information from the Electronic Power Steering module. If any of the following DTCs are set (history or current) in the EPS module or you are unable to diagnose the cause DO NOT CLEAR DTC(s), STOP FURTHER SERVICE ACTIVITY, complete the questionnaire below and contact PQC for further action.•
DTC C0569
DTC C0475
DTC C056E
DTC C0545
DTC C056D
DTC C055C
DTC C0544
For all other concerns where the above DTCs are not set, follow the published service procedures to complete the repair. Should the repair require steering gear replacement, contact PQC to review the diagnosis and order the part.
Please complete this questionnaire prior to contacting PQC.
Customer’s concern:
What is the customer’s description of the concern?
How many times did the customer indicate the issue occurred?
During which of the following driving condition(s) did the customer have a steering concern?
Low Speed turn Y/N
Straight-away Y/N
On a rough road Y/N
Was the concern temperature related? Y/N
Was the concern weather related? Y/N
Did the concern occur during an engine start (cranking)? Y/N
Please list any other conditions (if applicable) when the concern occurred.
What are the current and/or history DTCs?
Is the vehicle still exhibiting the customer concern? Y/N
Has the vehicle been modified with any aftermarket accessories or options? Y/N
What SI document number was used during the diagnosis?
Have the wires/harnesses been checked for proper routing and free from damage, stretch, pinch, etc.? Y/N (If no, perform this inspection prior to calling PQC.)
Have the wires been checked for any damaged, loose, or disconnected connectors? Y/N
(If no, perform this inspection prior to calling PQC)
Have any wire connectors or terminals been disconnected or loosened and then re-torqued? Y/N
Has the EPS supply voltage been checked on both sides of the EPS Fuse? Y/N
IF Yes, what was the voltage with ignition OFF? ___ Volts
(If no, you need to check and record voltages with ignition OFF prior to calling PQC. This fuse is not accessible; it is molded into the EPS power cable between the Battery Positive Junction Block and the EPS motor. Measure voltage at both ends of the EPS power cable)
Have you made any other observations or have any recommendations of what may be causing this concern?
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2012 General Motors. All rights reserved.
Customer Comments from this forum:
Boy this could get old.
We were just getting home from a hour drive and just as we get to the house
bamm!!!!..No p/s this would not be too safe if my girlfriend is driving it.
I let it sit for for just a little while and we out and it worked again.
The way it came back as I started it was like it had a bad connection and came to life just as the car started.
Will call the dealer to see if they have seen this yet here in phoenix AZ
Now that I get the paperwork back it says ".7 hr. Diagnostics of DTC C0475\00 lead to PIC5643E. Per PIC5643E regrogram P/S control module. Clear DTC's and verify no DTC's reset at this time. Warr code 313E3"
ADM PERFORMANCE is offline   Reply With Quote
Old 07-25-2015, 01:29 PM   #2
ADM PERFORMANCE
Please post your experiences
Please post your experiences in this thread, we need more attention here and less Excuses and Blames from Dealerships.
If you work for a dealership and are aware of this continuing problem and believe in telling the truth about what is causing it , feel free to share so that we can all live and breath easier
Old 07-25-2015, 01:39 PM   #3
snarky
ultracrepidarianism
snarky's Avatar
Drives: '14 1SS/RS/1LE/NPP '18 Accord Sport
usa today link fail
snarky is offline   Reply With Quote
Old 07-25-2015, 01:42 PM   #4
ADM PERFORMANCE
A list of codes
I have a list of common codes with descriptions:
C0475-00 Power Steering Motor Circuit
C056D-39 Electronic Control Unit Hardware - Internal Malfunction
C056D-3C Electronic Control Unit Hardware - Internal Communication Malfunction
C056D-3B Electronic Control Unit Hardware - Self Test Malfunction
C0800-12 Control Module Power Circuit - Low Input
Old 07-25-2015, 01:43 PM   #5
ADM PERFORMANCE
Originally Posted by snarky View Post
usa today link fail
Old 07-25-2015, 01:54 PM   #6
I've always worried about this happening again to my car again.
Pulled out of my garage after sitting for a week and the car was still brand new and the EPS was out. Pulled back in and called the dealer for an appt. Went out 3hrs later to drive to dealer and never had the problem again and of course they give zero details on what/if they did anything but clear codes.
2.5 years later and all is good, but it's like a ticking time bomb.
Old 07-26-2015, 08:28 AM   #7
ADM PERFORMANCE
Some information about why
The more I wrap my head around it the more I agree that it is the ground location and size.
The RED 12v+ wire is roughly 6 ga x 32"' long with what appears to be a very robust connector at the power distribution/jump start block mounted to the shock tower on the driver side. The bolt that holds this power lug is 8mm in diameter (same as your starter power inlet bolt) with a 13mm hex outside diameter that can be torqued between 17-29 ft lb give or take. Dam good connection if you ask me.
The BLACK 12v- wire is roughly 6 ga x 48" long with what appears to be a very robust connector at the end that grounds to the side of the car near the Intake. The bolt that grounds it is 6mm in diameter (the diameter of most grounds on the car that ground low current devices like lights, fuel pumps injectors etc.) with a 10mm hex outside diameter and small washer built in flange to aid in surface area.This bolt has a torque rating of 3-12ft lb give or take.
The codes that we are seeing are 90 percent voltage related, I have listed them here -
The math:
6 ga wire 32" long at 125 amps voltage drop is 1.9 percent not factoring in connection point size.
6 ga wire 48" long at 125 amps voltage drop is 3.3 percent not factoring in connection point size.
When electrical current moves through a wire it must surpass a certain level of contrary pressure. If the current is alternating, such pressure is called impedance. Impedance is a vector, or two-dimensional quantity, consisting of resistance and reactance (reaction of a built up electric field to a change of current). If the current is direct, the pressure is called resistance.
All this sounds terribly abstract, but it's really not much different from water running through a garden hose. It takes a certain amount of pressure to push the water through the hose, which is like voltage for electricity. Current is like the water flowing through the hose. And the hose causes a certain level of resistance, depending on its thickness, shape, etc. The same kind of thing is true for wires, as their type and size determines the level of resistance.
Excessive voltage drop in a circuit can cause lights to flicker or burn dimly, heaters to heat poorly, and motors to run hotter than normal and burn out. This condition causes the load to work harder with less voltage pushing the current.
Experts say that voltage drop should never be greater than 3 percent. This is done by selecting the right size of wire, and by taking care in the use of extension cords and similar devices.
The direction I am going with this is very simple - This wire that grounds this power steering rack is to small for its length and load it is expected to carry as well as its connection point size.The wire should have a shorter path to its grounding point,it should have a larger lug that has a higher torque rating and surface area.
Its obvious that the engineers put this part right on the edge of failure yet they made the voltage window it operates within super sensititive to triggering a code and going into limp mode(shut down mode).
For Liability Reasons we will not be offering a fix for this, only raw information of how it works and ideas that can aid in making it better.
Old 06-05-2016, 07:31 PM   #8
booneSS13
booneSS13's Avatar
Drives: 2013 Camaro SS LS3
Add me to the list. I have a 13 2ss, took it to the dealer. They said they cleared codes and 2 days later it failed again.
Here's a link to my thread:
http://www.camaro5.com/forums/showthread.php?t=454319
Romans 5:8
But God demonstrates his own love for us in this: While we were still sinners, Christ died for us.
-Fastlane Cold Air Intake, NPP cat back exhaust, Stainless Works LT Headers, 2r max camshaft, Stage 3 Ported Heads (Manley Stainless steel values, titanium retainers, dual valve springs, bronze guides), Wiseco Forged Pistons, K1 Forged Rods, Clevite Bearings, Factory Crankshaft, Comp Cams rocker arm trunion kit, Morel 5315 lifters, JP performance single billet timing chain, Melling oil pump, Spec stage 3+ clutch and flywheel, BMR trailing arms, Nitto 555r 305/35/20.
booneSS13 is offline   Reply With Quote
Old 08-03-2016, 09:09 AM   #9
Taco Time
Taco Time's Avatar
Drives: 2014 1SS
Glad I found this thread. I've had the power steering go out about 4-5 different times in the past couple of months. I've got some reading to do!
Taco's 2014 SS
Mods: 417 Stroker | CAI | Bo's PTB | Kooks LTs | Flowmaster Outlaw Catback | Night Fury Cam | Powerbond UDP | Apex Catch Can |PRC Ported Heads |FAST 102 Intake |Suspension Crap|
Built by J-Rod.
Taco Time is offline   Reply With Quote
Old 08-30-2016, 12:18 PM   #10
mcle6103
Drives: 15 ZL1
Power Steering just went out last Friday for the first time at 5400 miles on my 15 ZL1. It's very consistent, it happens about 10-15 mins after driving the car. All the dealership did was clear the code, tell me my tune may be causing it and sent me on my way but the problem came right back before I event got home. I'm hoping I found my problem though, the ground that wraps around the intake is rubbing/pinched which could be allowing in too much heat through the thinned section of insulation on the cable thus increasing the resistance of the wire which would cause a fault. Gonna wrap it up after work and put a shield around the cable, drive it and see if it sets again. If not then I gotta set the car back to stock, take it back to the dealership so they look elsewhere other than an aftermarket tune.
mcle6103 is offline   Reply With Quote
Old 08-30-2016, 01:05 PM   #11
ron123
ron123's Avatar
Drives: 2014 2SS/RS
That wire near the fender well heating up from engine bay would have no affect on the PS problem, the coating on the ground wire is there to cut down on copper corrosion, not to block heat from getting to the copper or affects of added resistance.
There are a huge number of wires laying all over the top of the hot engine at hundreds of degrees going to ignition coils, fuel injectors, sensors, emission controls and they do not have heat shields.
The wires/connectors adjacent to the exhaust manifold are shielded to keep insulation from melting, not to counter added resistance.
Ron
2014 2SS/RS, Z28 CAI and High Wing Spoiler, ZL1 5.1:1 Ratio Short-Throw Shifter, ZL1 Pedals, ZL1 splash guards, NPP Dual-mode quad tip exhaust, Z28 strut tower brace, Camaro LED Cup-holders with footwell Lighting option, Leather visors, and Leather E-brake boot. Chevy dealer sponsored 67 retro SS nose stripe package.
ron123 is offline   Reply With Quote
Old 08-30-2016, 01:24 PM   #12
mcle6103
Drives: 15 ZL1
I see your point but those other wires you speak of aren't in direct contact with steel that is possibly melting through the wire. But you're right, it's a long shot.
Old 08-30-2016, 01:28 PM   #13
mcle6103
Drives: 15 ZL1
The fact that it only happens as soon as the vehicle reaches operating temperature is what makes me think something is getting too hot
MY 15 ZL1
Headers, Intake, Tune
Old 08-31-2016, 06:40 AM   #14
mcle6103
Drives: 15 ZL1
Did not fix the problem as anticipated, gonna switch the pcm back to factory to rule that our then it goes back to the dealership
MY 15 ZL1
