Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Wheels and Tires Talk Sponsored by The Tire Rack
Old 03-14-2013, 01:35 PM   #1
SOLOJM
Drives: 2012 2SS 45th Aniversary Edition,
Nurburgring Offset Question
Looking at getting Front 20x9 and Rear 20x10 on my stock tires is the correct offset +35.
Thanks.
SOLOJM is offline   Reply With Quote
Old 03-14-2013, 04:16 PM   #2
MIKnam67
MIC
Drives: 2012 SSRS 6sp man Blk
Thanks.
My Nurburgrings are +35 front and rear 20x9 and 20x10
But I would ask seller
MIKnam67 is offline   Reply With Quote
Old 03-14-2013, 04:20 PM   #3
z28racer
z28racer's Avatar
Drives: 12 SIM 2SS/ RS Sinergy M6,GMC2500HD
I have 35 rear and 20 front.
z28racer is offline   Reply With Quote
Old 03-14-2013, 05:23 PM   #4
Denis
Denis's Avatar
Drives: 2010 SS
I'm running 20x9 and 20x10 with a 35 offset at all four corners.
Denis is offline   Reply With Quote
Old 03-14-2013, 08:54 PM   #5
SOLOJM
The sellar said 35 for both 20x9 and 20x10 just checking. He said I could do +20 in the front but I did not want to go that aggressive.
Old 03-14-2013, 09:21 PM   #6
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
Ideally using a 10" +35 rear you should have a 9" +20 front to have almost equal stance front and rear. If you use a +35 on the front, it will stick in 13mm more than the back.
Here's a link to a wheel offset calculator you can play with.
http://www.1010tires.com/Tools/Wheel-Offset-Calculator
I have all 20x10-35 on my car. Here's a side shot that you can get an idea how far a +35 sticks out in the rear.
bannonm is offline   Reply With Quote
Old 03-14-2013, 09:58 PM   #7
Denis
Denis's Avatar
Drives: 2010 SS
Here's some pics of +35's at all four corners.
Old 03-15-2013, 07:54 AM   #8
skar
skar's Avatar
Drives: 2010 2SSRS headers/CAI/tune/corsa,
I am with
bannonm on this!
35 rear 20 up front if you want the same wheel tire stick out .
Stainless works headers/cats Roto fab CAI /
Corsa install and tune Livernois
TSW Nuburgring 9 &10" x 20 on Invos (315 & 275 )
JL Audio XD400/4 amp
Pfadt trailing arms & tie rods sway bars.
pedders street 1 package. ,Hurst short throw shifter
With bronze bushings .
skar is offline   Reply With Quote
Old 03-15-2013, 02:45 PM   #9
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
Originally Posted by skar View Post
I am with
bannonm on this!
That's the setup I had (20" Nurburgrings +35 rear/+20 front) and it gives your car a more aggressive look compared to the +35 front/back.
But +35 up front will ultimately allow for a wider front tire.
SGOS252382 is offline   Reply With Quote
Old 03-15-2013, 03:10 PM   #10
NinoSS
Drives: 2SS/RS CGM LS3
What tire sizes are you guys running?
Current - 2018 NGM 1LE (LT4 conversion coming soon)
SOLD 2010 LS3 / Vengeance stage I cam / CAI intake w/ADM race scoop / Dynatech LT's / Eaton Posi LPE-JRE 3.91's / L99 Corsa / ZL1 wheels / NT05 275/315
NinoSS is offline   Reply With Quote
Old 03-15-2013, 03:17 PM   #11
skar
skar's Avatar
True but 275 up front and 315 in rear will work fine with me.
Old 03-15-2013, 08:50 PM   #12
bannonm
bannonm's Avatar
I run Michellin PSS, 285/35-20 on all four. Clearance is only an issue on the fronts but with the XAs I have on now it gives me about 1/2" of clearance to the strut. That's with a OE alignment. I'm switching to a track alignment in the next few weeks so waiting on camber plates to achieve that.
Old 03-15-2013, 09:00 PM   #13
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
20 X 9 with a +20 offset in all four corners. Running a 275/40/20 tire size. Love this set-up.
rtcat600man is offline   Reply With Quote
Old 03-16-2013, 12:42 AM   #14
Denis
Denis's Avatar
Drives: 2010 SS
275 up front, 315 out back. Nitto INVO.
