08-03-2016, 11:33 AM | #1 |
Drives: 2011 Camaro 2SS Join Date: Apr 2015
Rear tires only - Mix & Match?
I have a 2011 2SS with the stock 20" wheels. Front tires have plenty of meat left on them but rears are down to the wear bars. Don't have the capital to do what I want (ZL1 10 - 11 wheels and all new tires) and don't see the sense of tossing perfectly good fronts. I have Toyo Proxes all around. Is it advisable to get some Nittos or another brand for the rears or should I stick with the same until I do all four? Don't want to create some weird handling issue with mixed tires.....
RDame,
2011 2SS, L99 Auto, VMax TB, "Strong" MAF, MSD Wires, JRE Modded Metco Breather, DEI Plug Wire Heat Socks, Heater Hose Update, 160 degree Thermostat, CAI Intake, JRE CAI Scoop, Moroso Catch Can, ARP Header Studs, Dynatech 1 7/8 LT Ceramic Coated, Dynatech Supercats 2.5” out, 2.5" Corsa S Catback Resonator X Pipe,Moroso Driveshaft Hoop, Moroso Tunnel Brace, Goodridge Phantom G-Stop SS lines, Motul 600 RBF brake fluid, SCT 4 with JRE Tune |
08-03-2016, 12:04 PM | #2 |
Drives: '16 FiST Join Date: Apr 2012
You'll be 100%, perfectly fine.
08-03-2016, 12:15 PM | #3 |
Drives: 2010 2SS/RS Join Date: Jun 2009
I've run my proxies on front with different front with zero issues
08-05-2016, 05:41 PM | #4 |
Drives: Rally Yellow Camaro+Avalanche Join Date: Dec 2009
Just don't mix tires left and right.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM |
08-05-2016, 05:53 PM | #5 |
Drives: 2015 Chevy Camaro 1LE Join Date: May 2016
I'm having handling issues with having mixed set up but I also have a 285 Goodyear up front and 315 toyo in rear.
08-05-2016, 06:43 PM | #6 |
Drives: 2013 2SS (sold) Join Date: Jan 2016
Should be fine, but depends on what you will be doing with the car. If you are using those on the track it's probably not desirable but would still work.
And try to keep them in the same "class" for more predictable handling, for example don't use winter tires on the front and slicks on the back.
Track Parts/Stock Parts Part Out http://www.camaro5.com/forums/showthread.php?t=515534
