Old 04-02-2018, 07:08 PM   #1
Eldi Z
Drives: 17' 1SS 1LE GBA-Black
Scanner/Fault Diag. Handheld: Recommendations
Can anyone recommend a good, effective and easy to use device?
Web links would be useful.
Old 04-03-2018, 05:13 PM   #2
Eldi Z
Bump for my new SS 1LE Black-on-Black...
Would like to get a good Diag tool for her.
Old 04-05-2018, 11:26 AM   #3
Eldi Z
Bump once again for recommendations on a good scanner. Thanks
Old 04-05-2018, 11:57 AM   #4
Ecchi667
Ecchi667's Avatar
Drives: 2016 Camaro 2SS, 6spd M
I use the Veepeak Mini Bluetooth scanner along with the Torque app. Works great!
https://www.amazon.com/Veepeak-Bluet...dp/B011NSX27A/
Ecchi667 is offline   Reply With Quote
Old 04-05-2018, 01:34 PM   #5
Bodyslide
Bodyslide's Avatar
Drives: Traded in 2016 BLUE VELVET 2LT RS
I bought this one back in Oct and it works on my 16. I have used it a few times to on my Car and reset codes on my son's Sonata a bunch.
$35.00
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Bodyslide is offline   Reply With Quote
Old 04-05-2018, 06:50 PM   #6
Eldi Z
Thanks ! This is helpful.
I guess that something like the dealers' GM "Tech2" would be overkill and I think that today there is a very high yearly subscription rate when using the GM Diag tool via GM's service center servers (and probably open exclusively to dealers )
Old 04-06-2018, 06:20 AM   #7
Ecchi667
Ecchi667's Avatar
Yes, not really necessary. If you plan to use a handheld tuner at some point, you will likely find that those also read/clear codes, too.
https://rdpstore.com/c-2330-ecu.aspx
Old 04-07-2018, 06:23 PM   #8
Eldi Z
Thanks. Good input
