Old 02-18-2018, 12:23 AM   #1
GreyGhost1861
GreyGhost1861's Avatar
Drives: 2017 Camaro SS 1LE Hyper Blue
Replacing the headlights
How do you replace the headlights on the Camaro SS? One of mine went out. Sorry if this has already been posted.
GreyGhost1861 is offline   Reply With Quote
Old 02-18-2018, 09:22 AM   #2
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
Did you mean the bulb only or the headlight?
2SSRS@Gen5diy is offline   Reply With Quote
Old 02-18-2018, 08:39 PM   #3
GreyGhost1861
Just the bulb
Old 02-19-2018, 06:34 AM   #4
Ecchi667
Ecchi667's Avatar
Drives: 2016 Camaro 2SS, 6spd M
Just the bulb
Pop the hood and at the back of the headlight surround is a round, ridged "lid". Turn it and pop it out and you can get to the lamp. Unplug the cable and then twist the lamp and pull it out. That's the passenger side. For the driver's side I think you'll need to remove the air-box first in order to get at the lid, but I don't recall for certain.
Be sure you replace the lamp with the correct wattage unit. I tried a cheap Chinese one and it kept blowing the fuse. I'm pretty certain it was because the cheapies were 50w or 55w, and the stock lamps are only 35w.
Be sure not to touch the bulb on the new lamp. If you get grease from your fingers on it it'll reduce it's life expectancy. Wear clean gloves if you need to.
Ecchi667 is offline   Reply With Quote
Old 02-19-2018, 12:09 PM   #5
GreyGhost1861
Thank you
Old 02-19-2018, 12:10 PM   #6
Wierd Harold
Drives: 2017 2lt rs
Warranty?
Wierd Harold is offline   Reply With Quote
Old 02-19-2018, 02:10 PM   #7
ecko04
Drives: Too many to list
Originally Posted by Wierd Harold View Post
Warranty?
Bulbs are not a warrantied item unless there’s an covered electrical issue that caused the bulb to prematurely wear.
Sent from my iPhone using Tapatalk Pro
ecko04 is offline   Reply With Quote
