dave@hennessey
Old 06-05-2016, 01:22 PM   #1
SummitWhite1LE
SICC
SummitWhite1LE's Avatar
Drives: 2014 2SS1LE Summit White Camaro
Help c0710 code after lowering
I just installed 1" lowering springs now I am getting check stabilitrack light on and code c0710 it's on a 2014 camaro ss 1le. So you think it's just because the alignment is out that bad or did I pull something loose?
Sent from my HTC One M9 using Tapatalk
SummitWhite1LE is offline   Reply With Quote
Old 06-05-2016, 01:33 PM   #2
SPCBA
Drives: pleather and Chiclets
Bushing reclocked and alignment are pretty standard. Not sure you should be getting codes unless something out of bounds happened during install. Have installed or helped install quite a few springs on these cars no DIC message yet...
SPCBA is offline   Reply With Quote
Old 06-05-2016, 01:34 PM   #3
blake-b
blake-b's Avatar
Drives: 2009 ZR1
You likely knocked something loose or forgot to reconnect something. Check all your wheel speed sensors. You could have broken one of them.
I'm not aware of anything on the car that monitors the alignment.
Old 06-05-2016, 01:34 PM   #4
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Searching the code, it code c0710 shows as your steering wheel position indicator. If that is correct, you need to
1. Get al alignment becuase the front end i so far out of line it i tripping the code
or
2. Check the connections to your electric steering rack.
All you did is change coils?
JusticePete is offline   Reply With Quote
Old 06-05-2016, 01:41 PM   #5
SummitWhite1LE
SICC
Yep my steering wheel is way out of center so I have it an alignment shop right now hope it fixes the issue.
Old 06-05-2016, 01:42 PM   #6
JusticePete
They may need to relearn the center position. If the alignment doesn't do it, and the shop can't, your local Chevy dealer can.
Old 06-05-2016, 01:43 PM   #7
SummitWhite1LE
SICC
That's all I changed were coils
Old 06-05-2016, 01:51 PM   #8
JusticePete
Alignment should have you good to go.
Old 06-05-2016, 01:53 PM   #9
SummitWhite1LE
SICC
Thanks again Pete! I am on the rack now I'll let you all know how it goes
Old 06-05-2016, 02:55 PM   #10
SummitWhite1LE
SICC
Just got the car back from alignment , no more check engine light. Like Pete said my steering must have been that out of alignment after I lowered the car. Thanks again for all the help.
Old 06-06-2016, 07:59 AM   #11
JusticePete
