Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 03-05-2015, 07:19 AM   #1
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
Free boost modification
How many guys have done the bypass boost modification on their LSA engine where you slightly tilt your supercharger bypass valve counter clockwise to seal in boost a little better?
Tampa Tuning is offline   Reply With Quote
Old 03-05-2015, 07:31 AM   #2
Dutchman427
Dutchman427's Avatar
Drives: 2012 ZL1 #1329 M6
I am going to try it.
2012 Camaro ZL1 #1329 M6 Summit White
Built by Mike @ Rapid Motorsports
784rwhp 757 rwtq on 93 Octane ET - 10.97 @ 128
Heads-Blower-Snout-TB ported & prepared by Jeremy Formato of FasterProms
http://www.camaro5.com/forums/showthread.php?t=395950
Rapid Motorsports 396ci Build
https://www.camaro5.com/forums/showt...1#post10321301
10.832 @ 130.99
Dutchman427 is offline   Reply With Quote
Old 03-05-2015, 07:53 AM   #3
Kevlar382
Kevlar382's Avatar
Drives: '12 ZL1; '71 RS/Z28; '99 Vette Conv
That is very interesting, thank you for letting us know. Is there a down side to going this ?
Kevlar382 is offline   Reply With Quote
Old 03-05-2015, 08:17 AM   #4
nivek
Drives: 2015 ZL1 Black #100
Thanks for the info. That is something simple and definitely worth trying.
nivek is offline   Reply With Quote
Old 03-05-2015, 08:20 AM   #5
PsychoZL1
PsychoZL1's Avatar
Drives: 2015 Challenger SRT
Hmmm, I may have to try this.
PsychoZL1 is offline   Reply With Quote
Old 03-05-2015, 09:13 AM   #6
HDRDTD
If there is a slight opening as it comes from the factory, could it be intentional, and if so, what was the reason??
Old 03-05-2015, 09:29 AM   #7
vja 2014 zl1
Drives: 2018 Triple Black ZL1 A10
why not simply adjust the set screw?
vja 2014 zl1 is offline   Reply With Quote
Old 03-05-2015, 09:36 AM   #8
Kevlar382
Kevlar382's Avatar
Great question, I was wondering that too
Old 03-05-2015, 09:38 AM   #9
GenF-GTS
Drives: none
Just did it normally my boost swings between 7.83 - 8.55psi
Tonight I saw it hit 9.57psi and it was generally above 8.7psi usually sitting at 8.99 - 9.28psi
I also didn't undo the first bolt simply loosened the other 2 on the adjustment made sure i left 0.5 to 1mm clearance from the set screw.
I guess you do not adjust the set screw because it is harder to get to.
GenF-GTS is offline   Reply With Quote
Old 03-05-2015, 10:02 AM   #10
Jeb114
Jeb114's Avatar
Drives: 2021 300
Nothing is free somewhere down the road it will cost you!!!
Jeb114 is offline   Reply With Quote
Old 03-05-2015, 10:07 AM   #11
unstable vic
Drives: 2014 ZL1
This looks like a good one!!
unstable vic is offline   Reply With Quote
Old 03-05-2015, 10:23 AM   #12
kgendron71
REDHOT_ZL1
kgendron71's Avatar
Drives: 2014 Red Hot ZL1 M6
You guys rock!
kgendron71 is offline   Reply With Quote
Old 03-05-2015, 01:00 PM   #13
Joebot8484
ZL1 # 1307
Joebot8484's Avatar
Drives: 2012 Camaro ZL1, 2008 Hummzilla H3
ok i know what I'm going tonight.
Click on my signature for my build thread
Joebot8484 is offline   Reply With Quote
Old 03-05-2015, 01:14 PM   #14
shinzon
Night Fury
shinzon's Avatar
Drives: 2014 ZL1
Groovy, I will be watching this thread.
2014 Black ZL1 - Toothless -
Previous Lovers :2014 1LE , 2010 2SS RS,2004 GTO, 2000 Camaro SS x 2
shinzon is offline   Reply With Quote
