02-13-2024, 07:10 PM | #1 |
Drives: 1977 Pontiac Trans Am Join Date: Oct 2019
Rear Diff Oil
So I am getting the car ready for track season and I ordered some rear diff fluid 10-4034 (88862624) from Amazon received a bottle the first time and received 88865623, so I send it back and reorder and low and behold I receive the same thing. Then I notice there is a second label on the bottle over the first one and as I peel it back it has the correct numbers on it. So what is going on? I feel like it is good to use but wonder why they would relabel it. Has Gm changed the part number?
02-13-2024, 08:12 PM | #2 |
Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
It looks like the exact same thing, they've changed part numbers in the past. But 75W-90 with the friction modifier is what you want.
02-13-2024, 09:38 PM | #3 |
Drives: 2018 NFG 2SS 1LE! Join Date: Jul 2018
I just got two bottles as well. Same thing, new label over the old label. They also changed bottles, wider cap now so you'll need a different screw on pump if you manually pump into diff.
02-14-2024, 03:42 PM | #4 |
Yes, if you notice they decide to add French to the label to make it more North American to cater to the 1% French cocksuckers!! that’s what happens when you have a ****ing stupid liberal government! Spend spend spend
02-16-2024, 01:29 PM | #5 |
02-17-2024, 09:44 AM | #6 |
Drives: 2023 Sharkskin 2SS Join Date: Oct 2022
02-19-2024, 03:46 PM | #7 |
Drives: 2022 Camaro LT1 A10 Join Date: Nov 2015
2022 Camaro LT1 A10 - Drag Pack/AxleBack -11.849@118.67MPH/1.798 60' 2001 Camaro SS A4 - HCI/Stall/Bolt-on/Gear/Tune/DR/Diet - 429HP/392TQ - 10.99@123.58MPH/1.584 60' 1998 Camaro Z28 A4 - Bolt-on 1999 Camaro Z28 A4 - Stock FJB |
