12-02-2015, 10:18 AM | #1 |
Drives: 15' C7, 10' Camaro, 02' Camaro Join Date: Oct 2011
Interesting find while logging the first dyno pulls regarding intake...
If you want to hear some of the more technical aspects when it comes to intake design ill try my best to explain what i mean by this...
One of the first things we, as performance shops, look for when deciding on aftermarket intakes and designing them is looking at how well the factory intake is performing. And based on my logging its performing pretty bad..... when logging the intake manifold pressure we look for pressure in the manifold, specifically vacuum under WOT, meaning the car is trying to suck in air through the intake but the intake or something is holding it back. we log the INTAKE MANIFOLD ABSOLUTE PRESSURE measured in KPA... ATMOSPHERIC PRESSURE is equal to 99-103kpa depending on elevation, anything below 101kpa is vacuum and anything higher then 101kpa is pressure (like with a supercharger or turbo). while logging a stock 2016 Camaro SS i measured this parameter and found to to be 96kpa at 6200rpm, which is legitimate vacuum in the manifold (a little more then an inch of vacuum)... bring this number to 101kpa with a aftermarket intake would definitely improve hp at higher rpms..... I included a screenshot of the log... |
12-02-2015, 10:49 AM | #2 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
Is the SS intake the same as the C7?
I'm sure FAST or someone will come out with a better alternative. But, will have to see if it's really worth it for a bolt on car. |
12-02-2015, 11:28 AM | #3 |
Drives: 97Z,02TA Join Date: Mar 2011
Hes talking about the air filter box and ducting, not the manifold itself. So decent gains can be expected from a CAI
12-02-2015, 11:37 AM | #4 |
マスタング = 遅い
12-02-2015, 11:45 AM | #5 |
Drives: 2016 2SS Convertible Join Date: May 2012
It would be very interesting to see a comparison with Chevy's new Performance Air Intake for the 2016 Camaro. The web site claims "It is available for LT1 applications and reduces air intake restriction by 17% at peak airflow (350gr per second)." I think the intake includes a tune update to the ECU too.
12-02-2015, 01:10 PM | #6 |
We are going to start working on our own aftermarket intake soon, one that requires no tune and a larger one that will require a custom calibration, more for the guys running cams and things like that...
12-02-2015, 01:14 PM | #7 |
The Dogfather
Drives: #1 off the line for a customer. '16 Join Date: Oct 2015
Looking forward to it Josh! Boxed intakes are always too restrictive...
12-02-2015, 01:29 PM | #8 |
マスタング = 遅い
Not really true...if anything, most air intakes that have open filters make less power and aren't even true cold air intakes. All they do is pull in hot air. I'd take a well engineered "boxed" air intake that pulls air from the fender, or behind the grille, over one with an open filter 9/10 times. Looking forward to see what the aftermarket will give us...
12-02-2015, 01:43 PM | #9 |
Keep up the good work!!
12-02-2015, 09:53 PM | #10 |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
interesting read.
I'm still very interested in the GM intake and its supposed ECU flash it comes with. Maybe it gets much closer to neutral pressure.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
12-02-2015, 10:01 PM | #11 |
Sounds great! More choices are better! The Chevy performance intake is a bit spendy so lots of room for alternatives in the market!
12-09-2015, 01:47 PM | #12 | |
Drives: 2011 Camaro SS/ 2016 Camaro SS Join Date: Jun 2009
Kind regards, Jordan Priestley 888.308.6007 |
12-09-2015, 05:57 PM | #13 |
Drives: truck Join Date: Aug 2015
You're not the only one waiting for JDPM's car to arrive. Its clear people are really impressed with their SSs power/performance but you know that's going to eventually wear off and they'll be looking for even more. Keep us in the loop!
12-10-2015, 09:59 AM | #14 |
how does this compare to a factory stock LS3? if we know those numbers we can probably make some educated assumptions of gains that the LT1 will achieve with an aftermarket intake.
