Vararam
Old 03-21-2018, 01:25 AM   #1
ChattownGen5
ChattownGen5's Avatar
Drives: 2013 2SS/RS 6A
17" wheels on a 2013 SS
Definitely should've researched more but alas i jumped the gun. bought a set of 315/35R/17 NT05's from a friend today without looking at wheel options first... would i be okay running a 17x9.5 c6 z06 replica or would it not clear the rear brembo's?
ChattownGen5 is offline   Reply With Quote
Old 03-21-2018, 04:04 AM   #2
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Should be good. Race Stars are 17x9.5s and they clear fine.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 03-21-2018, 09:09 AM   #3
SSBUSDRVR
SSBUSDRVR's Avatar
Drives: '11 2SS/RS IBM/BLK M6
Like 2010_Camaro said should be ok However it could be an issue if Car lowered. Car lowered 1 inch here. Used BMR Adjustable lower Arms. Forgestar Drag Version F14 17x10 (M&H 325/45) would not clear OEM Arms. Would have seriously had to notch the hell out of them to even try to get them to fit and not rub under load.
'11 IBM 2SS/RS Built and Tuned by Vengeance Racing Vengeance PCM
Vengeance Racing Mast Black Label LS7 Headed 416
ProCharger Stage II D1X Race ,Monster Triple,Alky Control Meth Inj, Forgestar F14 Drag Version and a bunch of other blah blah blah.838/688 at 12lbs Street Friendly
SSBUSDRVR is offline   Reply With Quote
Old 03-21-2018, 10:19 AM   #4
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
Isn't a 9.5" a little narrow for a 315? People talk about putting 305's on their stock 20x9s and 50% of the comments are how that's a bad choice, the tire will bulge the center, etc. I would think you'd want a minimum of a 17x10.5 to make that tire lay flat on the ground. If you're already having to go rim shopping might as well make sure you get ones that are gonna work good for the rubber you've got.
GPI Max Package 2.0: Brodix BR7 heads/GPI porting, MAX3 cam, ST2116LSR, BSR Max Lift rockers, LS7 LSXR with 103mm TB, Vararam OTR, Mcleod RXT, G-Force/Strange 9" IRS setup with 4.63 gear. 551whp, 11.1@124mph.
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 03-21-2018, 12:17 PM   #5
ChattownGen5
thanks guys!
Old 03-21-2018, 12:23 PM   #6
ChattownGen5
how would a 17x11 with a 50mm offset fit? its a c4 ZR1 replica wheel.
Old 03-21-2018, 03:30 PM   #7
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
I could be wrong, but a 315/35R17 is a little short of a tire for your car isn’t it? That’s about 3 inches shorter than the factory tire isn’t it?
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 03-21-2018, 03:38 PM   #8
acammer
acammer's Avatar
It's a 25.7 or so. Definitely gonna throw the ABS lights on with stock wheels up front. With stock rear gears that'll give a nice boost in final drive ratio and get you a little more RPM through the traps. I guess we'd need to know the whole combo to really be able to say if that's a good tire for your setup or not.
Old 03-21-2018, 03:40 PM   #9
chuckie669
chuckie669's Avatar
Drives: 2011 ss
I think I have a 315/35-20 on mine which equals 28.7 tall.
Oe is 275/40-20 which equals 28.7 tall.
315/35-17 equals 25.7 tall
chuckie669 is offline   Reply With Quote
Old 03-21-2018, 08:42 PM   #10
BandRcAMARO
Drives: 2010 Camaro 2SS/RS
315/35/17 is under 26 inches tall while the stock tire diameter is 28.7 inches. If you keep the stock tires up front you will get ABS, stabilitrak, and all sorts of lights on your dash. You can do the fuse pull so that you can run it with no issues though. Racestar makes a 17x10.5 that fit on the rears with only having to tie back the e-brake cables. My car is lowered 1.4 inches with those wheels and same tires also, sits very low in the back but its just a track setup. Also the final gear ratio with the smaller tires is around 3.80 vs the M6 stock 3.45 gears.
2010 Camaro 2SS/RS
BandRcAMARO is offline   Reply With Quote
Old 03-21-2018, 10:09 PM   #11
ChattownGen5
these are used tires that a friend of mine was getting rid of. I'm gonna get a 305 50 17 or so shortly. just got these to mess around with. they've got a little life left in them so they're a good burnout candidate... hahaha
Old 08-06-2020, 12:54 PM   #12
05SilverStreak
05SilverStreak's Avatar
Drives: Black aSS 2011 - L99
305/45/17 Mickey Thompson Super Stickies here, less that .3 difference from stock.
Staying stock and loving it............
05SilverStreak is offline   Reply With Quote
