Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 10-23-2014, 07:23 PM   #1
Cooks ZL1
Drives: 13 Camaro ZL1
Adding a AFR Wideband to the Dashlogic
I am looking to see if anyone that has the Dashlogic has added a wideband to it to read air fuel ratio. I want to install a wideband now but looking for options that I wouldn't need a gauge. Trying to keep my Interior OEM looking.
If anyone has done something like this and or has a wideband of some sort installed on their zl1 I would like to hear about it. Thank you!
Cooks ZL1 is offline   Reply With Quote
Old 10-23-2014, 07:41 PM   #2
2K13_ZL1_BLove
Drives: 2013 Summit White ZL1
I have 3 aftermarket gauges. Steering column gauge reads fuel pressure. Then I have a dual pod a pillar with boost and wideband air fuel. All gauges are made my autometer.
2K13_ZL1_BLove is offline   Reply With Quote
Old 10-23-2014, 07:42 PM   #3
2K13_ZL1_BLove
Here's a better photo
Old 10-23-2014, 08:24 PM   #4
1709
9.56@144.09
Drives: 2013 zl1 black
does not the dashlogic give AFR,
1709 is offline   Reply With Quote
Old 10-23-2014, 09:15 PM   #5
2013 ZL1 #7860
Drives: 2013 ZL1 A6 #7860
AFR is read with a wideband sensor which is added.
You just need to determine the conversion from the 5v output of the wideband sensor to AFR and make a simple equation to do so automatically.
Then enter this into the dashlogic pin and your good to go.
I did this on my last car with an areoforce and it worked great!
2013 ZL1 #7860 is offline   Reply With Quote
Old 10-23-2014, 09:57 PM   #6
Unreal
Drives: 2006 Z06
Yes, it is super easy. Just run the 0-5v to one of the inputs on the dash logic, and enter the formula provided by the gauge.
Nick
Corvette Z06 -1200ish rwhp
Unreal is offline   Reply With Quote
Old 10-24-2014, 07:40 AM   #7
2013 ZL1 #7860
What wideband kits are people having luck with?
What bank are these being installed on?
Old 10-24-2014, 10:21 AM   #8
Unreal
Drives: 2006 Z06
I put it in the rear o2 sensor spot, since my rears are disabled, or just add a bung.
I use an AEM, but NGK, Innovative, etc all work great.
Nick
Old 10-26-2014, 06:32 PM   #9
tsnow
tsnow's Avatar
Drives: 12' ZL1, AGM 6M
Bought the PLX Wideband setup through Palmer when I purchased the Dashlogic but have not installed it yet.
If the Dashlogic freeze up issues were fixed I would be more motivated, may end up with a separate gauge to work with the sensor.
Have not heard from Palmer regarding freeze up fixes for a while, hoping it is still on their radar. It is a great product when working, too bad it isn't consistent.
tsnow is offline   Reply With Quote
Old 10-26-2014, 07:27 PM   #10
Unreal
Drives: 2006 Z06
Zero issues for the past year. It is just a ZL1 issue, and specific years/etc it seems. I'm sure they will get it working. The vette ones are trouble free, and certain zl1 years/etc. When they update the cars, there is bugs to work out. I'm sure it will be fixed.
Nick
Old 10-26-2014, 07:39 PM   #11
TrekGTO
TrekGTO's Avatar
Drives: 05 GTO / JETTA TDI
Don’t forget if you are adding the wide band after the cat you are going to be off a little. Adding a bung before cats is preferred, PLX Wideband since 06.
TrekGTO is offline   Reply With Quote
Old 10-27-2014, 05:17 PM   #12
Camero5
Hide! My wife's coming!
Camero5's Avatar
Drives: 2013 Chevrolet Camaro ZL1
I havent done it but I know Palmer offers an addon for the dash logic..
http://www.palmerperformance.com/sto...products_id=67
2013 Camaro ZL1 Convertible CRT - 630 RWHP / 620 RWTQ - ADM Performance Built/Tuned - ZL-700 Package - LS9 CAM - Lingenfelter CNC Ported Heads - Stainless Power Headers
Camero5 is offline   Reply With Quote
