Old 09-13-2017, 11:49 PM   #1
CamSS7
Drives: '17 Camaro SS
A8 Transmission
I took my car to the dealership because the downshift when braking slowly is a bit rough, especially at 20 mph ( downshift to 2nd gear). The mechanic went for a ride with me and he said its the computer doing that and he cant do anything about it, any ideas?
CamSS7 is offline   Reply With Quote
Old 09-14-2017, 12:02 AM   #2
Cameron27
Drives: 2015 2SS
Cameron27 is offline   Reply With Quote
Old 09-14-2017, 12:04 AM   #3
CamSS7
Originally Posted by Cameron27 View Post
Mine does it too.
I just don't downshift to 2nd gear. 3rd is sufficient.
I think it's a live-with-it thing. Someone posted in a thread I made that it may be an inherent quality that is just there.
yea I was hoping it wasnt a common issue, now I must use manual shifting when am down shifing then
Old 09-14-2017, 12:15 AM   #4
jaysonstuart
jaysonstuart's Avatar
Mine under hard acceleration or downshifting at highway speeds shifts violently from 4th to 5th. Dealer said they couldn't find an issue.
It shifts so hard from 4th to 5th under WOT that it spins the tires.
I should make a video of this nonsense.
jaysonstuart is offline   Reply With Quote
Old 09-14-2017, 12:18 AM   #5
Cameron27
Drives: 2015 2SS
Old 09-14-2017, 03:50 AM   #6
CamSS7
I'm confused. To downshift you have to do it manually.
I've never had full automatic mode downshift while breaking. No issues in full auto mode.
In tiptronic mode the only issue I have is shifting from 3rd to 2nd while slowing down. If speeding up it's fine.
while breaking slowly I put it in tiptronic to check what gear it did that on, saw it was 3rd to 2nd,but yea I meant full automatic downshifiting
Old 09-14-2017, 05:07 AM   #7
Burly
Burly's Avatar
I have noticed that my auto never downshifts to 2nd, it's always 3rd to 1st, even in performance mode.
Burly is offline   Reply With Quote
Old 09-14-2017, 05:27 AM   #8
NowaChevyGuy
NowaChevyGuy's Avatar
Drives: 2016 Camaro LT1 RS Black on Black
There is a software update for the tranny/ecu. My 16 RS was a GM Buyback so when I bought it I had my dealer check it all out and they confirmed it had the update. Maybe check and see if they need to apply it to yours. Mine shifts really smooth unless U pushed it into performance mode
NowAChevyGuy
2016 RS - Trifecta Tuned, 3.23 diff swap, Borla S Type, JMS Throttle Controller, Lambo doors, Monster stereo, GM LED rear tail lights, BMR swaybars/End Links/Trailing Arms, tinted dark and murdered out.[/br]
Car kicks ass! $20k.. and I get 20mpg with my foot in it, everywhere I go!.... Say somethin about V6's now...
NowaChevyGuy is offline   Reply With Quote
Old 09-14-2017, 11:17 AM   #9
Spartan268
Spartan268's Avatar
Drives: HB 2SS
That's normal. I had this happen in my other vehicles too. Don't know the exact reasoning for it but it seems to be the norm.
Spartan268 is offline   Reply With Quote
Old 09-14-2017, 07:08 PM   #10
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
I swear gm programs their transmissions to randomly downshift to hard and randomly upshift inconsistently hard. The worst part about it is that you don't know how it's going to shift next time.
Sent from my XT1635-01 using Tapatalk
cmitchell17 is offline   Reply With Quote
Old 09-14-2017, 09:46 PM   #11
CamSS7
Well I took it again and the mechanic did reset the gear ratios(its done by GMs servers he claims), and the problem is exactly the same lol.I guess i will just live with it, If anything happens to my tranny because of it ,then the dealer has record that I brought it up to them before and they did nothing
Old 09-15-2017, 10:09 AM   #12
cmitchell17
Looks like they did a relearn. It might make the shifts feel different for a little while but it will adjust back to its usual behavior. I've never owned a non gm transmission long enough to observe the shift behavior but I really do think the way gm programs the shift quality and timing dosent optimise smoothness.
Old 10-06-2017, 09:35 PM   #13
Cameron27
Drives: 2015 2SS
Old 11-21-2017, 02:09 PM   #14
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
I believe there is a TSB to reprogram shifting on the T4/V6 A8 transmission. If your Camaro doesn't have the update then you might want to check with the dealer about getting it.
I believe the A8 can be put into a "relearn" mode where it will recalibrate the shifts but I don't know if that will fix the problem or (as stated above) the transmission will just revert back to the way it is now.
I would take it back to the dealer and let them test drive with their diagnostics running to see if they notice a problem with the torque converter or transmission that is causing the problem.
transmission
