Old 04-09-2017, 08:30 AM   #1
Christian_smith94
Drives: 2016 Black 2SS
Angry Transmission mount snapped?
I'm guessing it was an over-time kind of wear out, but I went to do a burnout late last night, dropped the clutch and the car made a loud ass clang and just didn't have any motion. Motor revved up and that's all. Found a bracket with 2 bolts under my car with one of the bolts snapped clean. I eventually attempted to restart the car and it wouldn't turn over on the first attempt. Second attempt it finally did it and in turn fried the clutch up pretty nicely. Do you think Chevy will swap the clutch out seeing as it's pretty beat up due to this issue?
Christian_smith94 is offline   Reply With Quote
Old 04-09-2017, 09:28 AM   #2
buck50
Drives: 2021 C8, 2022 Camaro 2SS
I'm sure Chevy will swap the clutch out. The question is will it be determined to be a defects due to material and/or workmanship and therefore covered under warranty!
Order 9/09/2021,2022 2SS, NPP, 56W whls, B04 stripe, AQJ seats, N26 strg. whl., SLN brace
3000 1/19/2022
3400 1/25/2022 TPW 1/31
3800 2/15/2022
4300 2/19/2022
4B00 3/04/2022
4000 3/8/2022
Delivered 3/9/2022
____________________________________
Order 6/01/2016 2017 2SS, NPP, 56R whls
3000 6/08/2016
3000 6/15/2016 TPW 7/18/2016
3400 7/7/2016
4200 7/25/2016
Delivered 7/28/2016
Sold May 2020
buck50 is offline   Reply With Quote
Old 04-09-2017, 09:39 AM   #3
Christian_smith94
I mean it should be. They honor warranties for track defects, so that means even if I beat the living sh!t out of the car on the street it should still be honored I'd assume? Only way I'd expect them to not cover it would be if it was damage from an accident.
broken hoe = no fest, clutch, mount, transmission
