Old 01-21-2017, 06:52 PM   #15
OldJedi
Use the Force
OldJedi's Avatar
Drives: 2015 Corvette Z51, 2018 Porsche GTS
Send a message via AIM to OldJedi
Just a thought... but when they check the torque at several different HPDE's they always torque the lug nuts to 100 Ft. Lbs.
Walk softly, carry a light saber and drive a ZL1!
OldJedi is offline   Reply With Quote
Old 01-21-2017, 07:37 PM   #16
evanescent03
evanescent03's Avatar
Drives: '19 SS 1LE/'19 Rubicon/'20 AT4
My guess is it's because they don't have a manual for each car that comes through and at least they can confirm they're A) snug,and B) even all the way around. being even all around is probably more important than the being at the exact torque # (obviously the torque would have to be at least a reasonable number, 100 arbitrarily seems ok!)
evanescent03 is offline   Reply With Quote
Old 01-21-2017, 08:30 PM   #17
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
^ What he said.
Old 03-08-2017, 04:38 PM   #18
AZ_1LE
Drives: 2019 ZL1 1LE
140 ft lbs is insane for a 5 lug car, especially considering the size of the wheel studs and nuts.
100 ft lbs for me, every time. The first time I ever took the wheels off of the car when it had 15 miles on the odometer, I cracked them loose with my torque wrench which was set to 90. They DEFINITELY were not at 140.
Old: 2017 SS 1LE
Old: 2017 ZL1
Current: 2019 ZL1 1LE
AZ_1LE is offline   Reply With Quote
Old 03-08-2017, 08:18 PM   #19
NBR IPD
NBR IPD's Avatar
Drives: 2017 SS 1LE
Why not just go by the owners manual for everything? GM engineered the car to perform safely and effectively using the specifications communicated in the owner's and service manuals. The bolted hub joint has a specification of 190 N-m for a reason - probably not an arbitrary number. I'm guessing it's that high to prevent torque loss in the wheel/hub/bearing joint when exposed to the high forces it can have from braking, accelerating, and cornering.
Mine came from LGR factory with an average of 185 N-m breakaway torque on all the lugs. So pretty close to the spec of 190 N-m and probably the difference between my calibrated torque wrench and the factory tightening method.
2017 SS 1LE Hyper Blue - PDR - TSSHKX
2017 SS 1LE Hyper Blue - PDR - VBHF63
NBR IPD is offline   Reply With Quote
Old 03-13-2017, 08:23 PM   #20
Gville1LE
Drives: 2006 Lexus IS350
Coming from a mag seat style lug nut on my Lex (75 ft lbs), I'll have to remember this for when I get myself an 1LE. And I'll have to get a larger torque wrench as well!
Gville1LE is offline   Reply With Quote
Old 03-14-2017, 08:39 AM   #21
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
I was worried I would have to do the same. Was glad to see my Snap On actually goes up to 250. You can borrow mine when the time comes since you seem to live just down the road from me.
Old 03-14-2017, 08:54 AM   #22
Corner carver
Corner carver's Avatar
Drives: 2017 Camaro 2.0T RS
This is the wrench I use. 250lb limit so 140 is nothing, no elbow grease required.
...I just use body weight with the same kinda leverage...
As Delivered: 2017 Mosaic Black 1LT RS 2.0T | M6 | HD brake and cooling | Bose & 8"screen | Front lip extension | Blade spolier | Black bowties | Painted splash guards
Installed Mods: 25% Window tint | Headlight, side marker and third brake light Phastek tint kit | GM black taillights with Gen5diy LED harness and bulbs | LED license plate bulbs | Gorilla lug nuts, black | GM 'performance' center caps | RS and sheild badges removed
Old 03-14-2017, 08:56 AM   #23
LSmith353
LSmith353's Avatar
Drives: 2015 Ultimate Track SS
These are the exact same size studs I have on my Dodge 2500 4WD Cummins. Torque spec from Chrysler is 140 lb./ft. Pretty sure they are same on a Silverado.
Having said that, at my last HPDE, I rechecked the lugs after the first outing (they were torqued to 140 cold) and 2 were loose. I left the torque wrench @ 140 and re-tightened. One tightened up, but I stripped the threads on the 2nd one. I won't be using 140 when they're hot anymore. Probably 110 max.
2015 2SS Ultimate Track Camaro
https://www.racingjunk.com/news/2014...ack-camaro-ss/
2016 2SS M6, MRC, NPP, Nav, Sunroof -- SOLD
2010 2SS/RS M6 -- SOLD
LSmith353 is offline   Reply With Quote
Old 11-02-2018, 08:19 AM   #24
18ss376
Drives: Camaro
I was only going to 100 ft. lbs. because on my 8 second race car it was 130 ft. lbs. so I thought it would be way less on a stock car.
18ss376 is offline   Reply With Quote
Old 11-02-2018, 08:43 AM   #25
Goldfish
Drives: 18 2SS 1LE
Just to be clear, torque specs are not arbitrary. If the engineers say the bolted joint needs 140 ft*lb, there is a reason for it. Using less torque than a bolted joint is designed for can lead to loosening, fatigue, and failure. Be sure to apply the correct torque with the specified lubricant (or lack of lubricant), otherwise you will under/over torque and have potential issues as well.
Source: I design products containing bolted joints for a living.
Goldfish is offline   Reply With Quote
Old 11-02-2018, 08:53 AM   #26
Dave-ROR
Drives: A few
I know this is old but since it's already been revived...
You tightened them when they were pretty hot still I assume? It's far easier to break/strip a lug stud at 600 degrees F than at 100 degrees...
I never tighten hot lugs unless I'm running a real bolt/stud/etc (ARP/etc)
-Dave
HPDE/DD: 2018 Camaro ZL1 1LE || HPDE/DD: 2015 Subaru BRZ ||Tow Vehicle: 2004 GMC Sierra 2500 8.1L || Weekend toy: 1994 MR2 Turbo || The other weekend toy: 1993 MR2 Turbo || Track car: 1998 Integra Type-R || Race car: 1996 Integra GS-R || New race car build: 1992 Honda Civic Hatchback
Too many cars.. never.
Dave-ROR is offline   Reply With Quote
Old 11-02-2018, 09:08 AM   #27
Emoto
Sure, why not?
Emoto's Avatar
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon
Thank you. Nothing bugs me more than when people randomly decide that the torque spec should be something other than what the manual specifies.
Emoto is offline   Reply With Quote
Old 11-02-2018, 09:14 AM   #28
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
And lots of other stuff, because (insert auto mfg'er conspiracy theory here).
