Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LLT Engine, Exhaust, and Bolt-Ons
Old 05-21-2019, 07:40 PM   #29
gringo
gringo's Avatar
Drives: Camaro V6
Originally Posted by Elite Engineering View Post
Cloyes has a great video. Watch it several times before you start as some of the timing is tricky:
And of course, to avoid failure in the future ONLY use full synthetic oil, and make sure it is not the super thin viscosity the owners manual states. A 0w40-50 is best on all GDI engines. A 5w50 is also good. And of course, install our E2-X catchcan system with cleanside to keep that oil clean as possible, and while you have the intake manifold off, search for the intake valve cleaning threads on here and do the same. You wont believe the difference it makes to get 15-20 HP back.
Cheers!!!
Tech@EliteEngineeringUSA.com Sales@EliteEngineeringUSA.com
Is an oil that thick in viscosity good though? I thought the whole point in using an oil that's thin was for the components in the VVT system.
gringo is offline   Reply With Quote
Old 05-22-2019, 02:14 PM   #30
Dawid
Drives: Camaro
0w30,40 or 5w50 oil are a better choice than the 5w30 instruction manual?
Dawid is offline   Reply With Quote
Old 05-25-2019, 06:11 PM   #31
MX2Forty
Drives: 2010 Camaro RS
Thanks guys for all the advice. I tore into it last night. Power steering pump makes the one bolt a little bit of a pain. Lot of electronics on these! I will take the timing cover off tomorrow morning. It’s all ready. I was surprised that the top two chains weren’t that loose? Haven’t seen the bottom one yet. I did get the solenoids to change out.
Back at it tomorrow.
MX2Forty is offline   Reply With Quote
Old 05-27-2019, 07:27 PM   #32
MX2Forty
Done!
Change the oil tomorrow and I should be good. Probably need to get a new harmonic pulley bolt?
Old 06-03-2019, 06:45 AM   #33
fnhowe84
fnhowe84's Avatar
Drives: 2018 Hotwheels M6 & 2010 1LE V6 M6
Id say yes to the bolt. I replaced mine for my timing replacement.
CamaroLIFE
fnhowe84 is offline   Reply With Quote
Old 07-17-2019, 06:37 AM   #34
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
Long time folks! Just rereading this thread...lol memories!
Time to update everyone
CAMARO
Consult your doctor before taking Camaro
Side effects include Sudden increase in Heart Rate, Insomnia and occasional hallucinations
If you experience Permagrin exceeding 4 hours after taking Camaro, seek immediate Camaro5 Help
CAMARO Bringing excitment back into the Garage
TJ91 is offline   Reply With Quote
Old 10-21-2019, 08:32 PM   #35
Chicoblanco90
Drives: Camaro rs 2012
I'm doing mine right now I cant seem to get to the 2nd phase of the timing my crankshaft wont route anymore I'm about a 1/4 off of 9 o'clock for second phase anybody have any ideas ?
Chicoblanco90 is offline   Reply With Quote
Old 10-22-2019, 08:40 PM   #36
JJPlace1
JJPlace1's Avatar
Drives: 2010 2LT Victory Red
i would start over with the chains if you run into issues like that , just to be safe !!
Previous Vehicles
1970 Impala 2D 350/300
1972 Buick GS 350
1967 Pontiac Firebird 326
1969 Chevelle SS 396/375 I really miss this one
1966 Chevelle SS 396/350
1978 Plymouth Fury 440
1982 VW Scirocco ( Got married )
1987 VW Scirocco
1992 Ford Taurus V6
1996 Dodge Intrepid
2002 Dodge Intrepid
2002 Mercedes ML500
2010 Camaro 2LT
JJPlace1 is offline   Reply With Quote
Old 06-14-2020, 10:16 PM   #37
bandier
Got mine!
bandier's Avatar
Drives: 2021 LT1 RS - Orange Crush
I've gotta do my timing chain now, just got the P0008 code. Watching the Cloyes video doesn't make the job look bad at all. How tough is it to get to that point?
Camaro lover since 1984 when I got my first car a 1978 Camaro LT with a 2 barrel carb on 305 V8... yes I put in a 350 with a 4 barrel.
bandier is offline   Reply With Quote
Old 05-25-2021, 02:08 PM   #38
secrethero89
Drives: 2011 3.6 V6 RS Cabrio
did you fix your issue?
secrethero89 is offline   Reply With Quote
