TireRack
Old 06-23-2016, 06:12 PM   #1
SSCamaroZ28
Drives: 2013 ZL1
For people that have driven both FE3 and FE4 SS Camaros
I was wondering for those that have experience with both suspensions if you actually felt a difference on the street upon normal and spirited driving? I'm looking to find a 10-13 SS and am wondering if I should hold out for a 12 or 13 because of the improvements made to the suspension and otherwise over the other two model years. I'm really not looking to modify the suspension, so is it really that much of a difference?!
2013 Camaro ZL1 M6 Black/Black 21,000 miles. #6944 of 7956. 1 of 1208 black manual coupes.
SSCamaroZ28 is offline   Reply With Quote
Old 06-23-2016, 09:38 PM   #2
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
The outboard style rear bar transforms a 5th Gen. You can either find a good deal on a newer style suspension from the factory or budget for the upgrade on a older model.
JusticePete is offline   Reply With Quote
Old 06-23-2016, 09:49 PM   #3
hammdo
'It's an experiment'
hammdo's Avatar
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE
JusticePete is right. I did the change and love it. Transforms the car. Worth changing the FE3 LCAs to the FE4...
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari
See My Build: http://www.camaro5.com/forums/showthread.php?t=385577
hammdo is offline   Reply With Quote
Old 06-23-2016, 10:26 PM   #4
SSCamaroZ28
Drives: 2013 ZL1
Hmmm really? What were the actual differences you guys noticed?
Old 06-24-2016, 11:07 AM   #5
KillboyPowerhead
Drives: 2015 Z/22
I have a 2014 V6 so I went with JusticePete's sway bars because his outboard-mount rear bar does not interfere with the rear brakes like that rest of them do (so I've read); these bars make a huge difference in higher-speed handling by significantly reducing body roll, and with the bigger rear bar you can corner that much harder before understeer kicks in (compared to the factory bars).
In your case you could go with a 1LE/ZL1 rear bar and keep the SS front bar (same front-to-rear 5mm bias as JP's bars), or if you can spend a few more $ you can go with bigger aftermarket ones.
KillboyPowerhead is offline   Reply With Quote
Old 06-24-2016, 12:45 PM   #6
JusticePete
-Don
Old 06-25-2016, 04:04 AM   #7
SSCamaroZ28
Drives: 2013 ZL1
So would you guys think to go for a 12 or 13 for more money or go for the cheaper earlier models and upgrade the suspension?
Old 06-25-2016, 10:02 AM   #8
JusticePete
It depends on the car and the price of the car. A killer deal on a pristine low mileage 10 vs a good deal on a high mileage 14, I'll take the 10 and update the suspension.
Old 06-25-2016, 03:56 PM   #9
SSCamaroZ28
Drives: 2013 ZL1
I'll keep that in mind. Thank you all!
