11-28-2017, 06:46 PM | #113 | |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
11-28-2017, 06:52 PM | #114 | |
11-28-2017, 08:43 PM | #115 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
The SS 1LE has Super Car 3 tires. Not quite like the Cup 2’s, but they are way, way better than the run flats on the SS, and will last five times longer than Cup 2’s.
11-28-2017, 09:02 PM | #116 | |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
I think the A8 is just fine for the SS. Adding the A10 will just increase cost and make take away from it if you ask me. |
11-28-2017, 11:31 PM | #117 |
Honestly I would not want to deal with a any more gear changes....8 is already borderline.
2016 NFG 1SS A8
11-29-2017, 08:41 PM | #118 |
The SS needs the A10... trust me on that one. Especially tuned like it is in the ZL1.
11-29-2017, 09:13 PM | #119 |
Drives: 2007 Trailblazer SS Join Date: Oct 2017
Lund just put 462/431 tuned on E85 with JLT intake. Thats FBO with manifold 15-17. Pretty nice.
11-29-2017, 09:23 PM | #120 |
Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
What was baseline?
On happy dyno FBO 15-17 seen close to 500 rwhp. Seen several 480+. Cobra jet with larger TB will get highest numbers |
11-29-2017, 09:49 PM | #121 |
I want to say Lunds baseline was 430/400. Usually boss manifold/ shelby manifold setups are in the 460ish range. CJ and single blade a bit higher.
11-29-2017, 10:01 PM | #122 | |
So they gain big like the Camaro. 30-40 rwhp. But also Lund said they didn't get a ton on 93. Like the Camaro. Must be the new DI allows aggressive tuning from the factory. |
11-29-2017, 10:14 PM | #123 |
Drives: 2017 Camaro SS 1LE Join Date: Apr 2017
Peak power #s the 5.0 will have the advantage over the LT1. I hope Chevy implements PI on future LT1s.
Is there any aftermarket intake manifolds with PI? |
11-29-2017, 10:25 PM | #124 | ||
If I know anything about JLTs on the S550 is that they LOVE heat. I mean, they get extremely hot. All the open intake systems do. I had an Airaid on mine with the insert cut out. I then switched to JLT just because I liked the looks. My temps got soo hot I got rid of it. On relatively cool days my temps would hit 130s, 140s after about 20 min driving. So while this dyno may look good because they gave the car plenty of cool down time and probably dynoed it with the hood open, I'm betting it'll start pulling timing, losing hp, and will be slower after a few minutes of driving with the hood closed. |
11-29-2017, 10:41 PM | #125 |
They'll hit 500 on ftw purple
11-29-2017, 11:23 PM | #126 | |
