11-30-2017, 12:51 AM | #127 |
Drives: 600whp 2016 C63 AMG/ 2018 SS 1LE Join Date: Apr 2017
Yeah and the camaro is a ~455whp car with his mods and 200lbs heavier with the passenger. That looked like way more than a 40whp difference especially with the gearing of the mustangs a10. Very high reading dyno I would say. I think on a proper dyno the car would be =/<410whp.
11-30-2017, 11:21 AM | #128 | |
Drives: 2013 GB GT Join Date: Mar 2016
11-30-2017, 12:23 PM | #129 |
Revolution Auto got 20whp with a tune only on 93...same day back to back
11-30-2017, 03:37 PM | #130 | |
Drives: 2019 Camaro ZL1 Join Date: May 2017
Is that impressive to some? If I void my warranty then I better get 20hp.
1987 Camaro V6 1988 Camaro IROC Z 1993 Camaro Z28 1999 Camaro SS 2017 Camaro SS |
11-30-2017, 06:09 PM | #131 |
11-30-2017, 06:13 PM | #132 |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
11-30-2017, 06:18 PM | #133 |
Geez man, some of you guys are acting like the 18 GT is breaking barriers or something, lol!! It isn't doing anything special or new or different. Some pro shop with unlimited resources buys one and loads it up with mods and does this or that and you guys are acting like it's magic or something. I mean, if you guys are impressed with the 18 GT, then you all should have went bonkers when the 16 Camaro SS came out. And the 18 GT still isn't gonna compare on the track. And you have to buy a certain specific GT to be fast...unlike the SS, any of them will do a low 12. There is nothing impressive about the 18 GTs. They're better than the 15-17s by a small margin and maybe that's enough to impress Mustang folk since they've been lagging behind for this long. But it isn't anything that impresses us over here.
11-30-2017, 06:30 PM | #134 | |
a couple days ago Lund made it sound like there was litle to gain from a 93 tune...20whp has been standard for years , so what's Lund going on about was my point. |
11-30-2017, 06:41 PM | #135 |
Drives: 2SS 1LE Join Date: Oct 2011
Maybe gt350 IS supposed to die, replaced in a few months with gt500?...
11-30-2017, 06:43 PM | #136 | |
Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
You can let a car cool, change pressure in tires, strap it down different,hood open vs closed, take off a belt etc etc....and make the numbers higher. Among other things. Some shops said the same about the Camaro on 93. And then Ive seen other claim plenty of gains. Its hard to know whats really going on. Kind of sad. The track is the only place that wont lie...and in my opinion these newer DI motors wont gain a ton of hp from 93. But you will see gains from optimizing things like TM removal, shift points etc on a regular 93 tune |
11-30-2017, 07:42 PM | #137 | |
The GT500 is too scared to come out. The Mach1 went into hiding. The Boss fled. The Bullitt changed it's identity. And anything else that Ford has with a name on it is running with it's tail between it's legs... |
11-30-2017, 08:03 PM | #138 | |
Drives: 1969 Mustang MaCh1 Join Date: Nov 2015
Sent from my SM-G955U using Tapatalk
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtqT56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear |
11-30-2017, 10:58 PM | #139 |
11-30-2017, 11:34 PM | #140 |
Drives: 2007 Trailblazer SS Join Date: Oct 2017
Your mad surfaces plenty often in these threads.
