Old 05-04-2021, 08:03 AM   #1
StopShoe
Drives: 2017 Camaro SS
High LTFT and Misfire
My car has a problem with misfiring when it starts cold, always cylinder 4. HPtuners shows it misfires around 80 times, and then once the idle dies down it mostly stops. However, anytime I let off the gas from light acceleration, cylinder 4 misfires twice. I have a few other cylinders that misfire a few times but I understand that is mostly normal.
I also noticed that my LTFT reads pretty high, anywhere between 15-25%. I got P0171 and P0174 codes while driving the other day, about 20 miles after I used the CRC intake cleaner. I have a log from a few months ago where it showed my LTFT being between 0-5%.
I have tried the following to fix it:
Cleaning the intake with CRC intake cleaner
Swapping the coil packs and wires between cylinder 2 and 4
Bottle of techron fuel cleaner in the tank.
Spraying small amounts of ether around every vacuum line I can find, but no surges or changes on idle when I do it
Cleaning the MAF sensor with CRC MAF cleaner
At this point I'm not sure what the problem is. Someone said it could be an 02 sensor that got dirty after using the CRC/techron, but the o2 sensors still read as normal when I compare recent logs to past logs. Could it be a bad injector?
Mods: E85, GM CAI, Borla Axleback
StopShoe is offline   Reply With Quote
Old 05-04-2021, 08:27 AM   #2
NA18CamaroSS
NA18CamaroSS's Avatar
Drives: 2018 Chevrolet Camaro 2SS 1LE 6M
List your mods-it may help to troubleshoot.
Try a fresh set of plugs.
It could be an injector-if you don't have any vacuum leaks, that could be the cause of your misfire and your high fuel trims.
Bolt-ons.
NA18CamaroSS is offline   Reply With Quote
Old 05-04-2021, 08:39 AM   #3
StopShoe
I knew I forgot something. I edited my post with the mods.
So even if I have 1 injector that is bad/failing, it would cause high fuel trims on the other bank?
Also, when looking at the car from the front (cooling reservoir on the left), it goes 2, 4, 6, 8 with 2 being the closest to me, right?
Old 05-04-2021, 09:37 AM   #4
NA18CamaroSS
Firing order/cylinder layout. Except that the firing order is : 1 – 8 – 7 – 2 – 6 – 5 – 4 – 3
Bolt-ons.
Old 05-04-2021, 10:45 AM   #5
StopShoe
Perfect, that is what I thought it was but I figured I'd ask just to be 100% sure.
So on the injectors, if 1 is bad it can cause both banks to read as lean?
Old 05-06-2021, 07:19 AM   #6
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Unmetered air entering the system can cause false positive fuel trims. Check all your connections between TB and Maf.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 05-13-2021, 08:23 AM   #7
jasonz28camaro
Drives: 2007.5 Duramax
What’s your alcohol content reading currently? If your flex sensor is not working correctly it would dump around that much fuel.
Built C6Z 600whp NA - SOLD
Built LSX 96SS - SOLD
68 Camaro - 6.2/10l80, self built and tuned.
jasonz28camaro is offline   Reply With Quote
Old 05-19-2021, 04:28 PM   #8
jimadvig
Drives: 2018 Camaro 1SS
My fuel trims were about 17% high when I took my car to the dyno. I thought that maybe my wideband or O2 sensor was bad. After talking to my tuner and sending him my dyno logs he informed me that I needed to go to a 95mm TB as my current TB (Solar 87/91 ported) was causing it to pull vacuum and running rich. I have currently swapped out the TB for the 95mm and working on the new tune. Hopefully that takes care of my rich condition at WOT.
Camaro 1SS M6 - LT2 IM, 1-7/8" Speed Engineering Headers & catless 3" x-pipe to Borla ATAK NPP axle back, Mishimoto Catch Can, BTR Rocker Arm Trunnion kit, E85, 95MM TB, JLT CAI, 180* T-Stat, & SJM line lock - Tuned by Ted Jannetty
jimadvig is offline   Reply With Quote
Old 03-13-2024, 04:37 PM   #9
16ssFR
Drives: 2016 Camaro 2ss
Did you ever figure out the issue? My car is also misfiring on cylinder 2 only when I’m on E85. Have headers, manifold, X pipe, intake, tune. Just ordered a 95mm TB. During logs, my TB only opens to around 56% during WOT.
16ssFR is offline   Reply With Quote
Old 03-17-2024, 08:22 AM   #10
JANNETTYRACING
JANNETTYRACING's Avatar
I retuned it and all is well.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
