03-02-2021, 12:23 PM | #1 |
Drives: 2011 Camaro LT Join Date: Jul 2020
Anyone know of any good V6 brake swaps?
Looking to find a new set of rotors with painted calipers for my 2011 V6.
03-02-2021, 01:05 PM | #2 |
ZL1 swap.
Orange Krush II
03-02-2021, 02:22 PM | #3 |
03-02-2021, 02:43 PM | #4 |
have seen some nice rotors on tire rack.com.i think they were anodised to prevent rust.i just painted my stock calipers with red ceramic brake paint and they look good,will get new rotors whenever the pads wear out.
03-02-2021, 03:33 PM | #5 |
03-02-2021, 03:36 PM | #6 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
I have a front set of red brembo calipers off my 1LE from when I upgraded to six pistons. I've heard of V6 guys upgrading to the four piston brembos but not sure what else you would need.
Sent from my Pixel 5 using Tapatalk
830 WHP 700 WTQ, Whipple 2.9 @ 13lbs Boost, Flex Fuel Tune by Blevins Tuning, LSA SBE, 3.5 GripTec, ATI LS3 Damper, AFR 260cc Mongoose, ARP Studs, Yella Terra Ultralites, Johnson 2110R, BTR PDS Stage 3, Melling 10355, Improved Racing Baffle, ID1050X, DSX Triple Fuel Pump, RotoFab CAI, NW 103mm TB, Stainless Works 1-7/8" LTH to 3" Speed Eng w/ X-pipe to NPP, Powermaster 9509 XS, Detroit Speed Motor Mounts, MGW, Monster LT1-S, ZL1 Calipers, DBA Rotors & Pads, Bilstein B6 Struts & Shocks, BMR 1.25" Drop Springs & Adj Rear Bar, Pegasus Solid Bushings, Z/28 Wheels, other misc parts.
03-03-2021, 04:28 PM | #7 |
SHKE BKE
Drives: 2013 Camaro Join Date: May 2014
i put the 4 piston brembos on mine, just need rotors, calipers, pads, rear brake lines. you need to modify the rear brake dust shield to make it fit, or to do it right you can replace it. i also replaced the front brake lines just because i got steel braided lines front and rear but that's optional, as is the master cylinder which i never replaced and had zero issues
03-03-2021, 07:03 PM | #8 |
Sporting Foole
Drives: 2010 Camaro SS Join Date: Sep 2019
The 4 piston Brembos are pretty damn good, I can’t imagine how the 6 piston fronts will haul it down. Stoppies in a Camaro?
