Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 10-19-2020, 09:50 PM   #1
frey.199
Drives: 2010 Camaro 2SS
Throttle Body
Just looking for some opinions. I think my throttle body is bad. I have the P2135 code and pulled my TB off and tested it with a multimeter. Their seems to be a short intermittent over load on TPS 2 while pushing in and releasing the plate of the TB like it's not functioning correctly. However, my main concern is the fact that this TB is maybe only a year old. It's a stock GM TB and I don't get why a TB would go bad that quick. Is their anything in the wiring harness that could have caused the TB to go bad or anything else? TB's aren't cheap so I don't want to slap a new one on necessarily if it's only going to fry the next one. I'm looking for any thoughts or opinions.
frey.199 is offline   Reply With Quote
Old 10-19-2020, 10:42 PM   #2
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
are you using any type of throttle controller on the accelerator pedal
Sent from my SM-G975U using Tapatalk
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 10-20-2020, 03:34 AM   #3
mikeman
Drives: 2015 Camaro
Did you buy the TB? I think there's a 24 month/unlimited mileage warranty for genuine GM parts. I'm not sure if there could be anything in the wiring that would cause it to short out like that. That what fuses are to protect. However, I guess anything is possible with these complicated cars.
mikeman is offline   Reply With Quote
Old 10-20-2020, 07:54 AM   #4
frey.199
I am not.
Old 10-20-2020, 07:55 AM   #5
frey.199
Maybe I'll try contacting GM about it that warranty. I plan on testing the wiring harness if I can.
Old 10-20-2020, 10:10 AM   #6
TommyTheCat
SHKE BKE
TommyTheCat's Avatar
Drives: 2013 Camaro
I thought it was 12 month 12,000 miles?
TommyTheCat is offline   Reply With Quote
Old 10-21-2020, 08:15 PM   #7
frey.199
I just checked it is two year warranty. Lucky me, I don't have a receipt from a year ago and the original dealership now has new ownership and no previous records of me purchasing it. So I'll just have to get another.
I guess my worry at this point, if I get another GM throttle body, is it going to give out in another year? Is their another underlying issue? I can't think of any other way something else could cause the TPS to blow or short out in the original one. Assuming that a new TB is the fix to my problem because running an ohm test, this one seems to be fine.
Old 10-22-2020, 07:45 AM   #8
xc_SS/RS
Drives: 2010 Camaro SS/RS
I doubt you’ll have the same issue
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
