11-21-2023, 10:52 AM | #1 |
Drives: 2018 Camaro SS 1LE Join Date: Oct 2019
Harness Help
I am adding a roll bar, seat, and a 6 point harness. But the prices of the harnesses vary pretty dramatically. I was told the difference comes down to friction resistors.
Im looking at OMP harnesses and their OMP one versa is over $100 more than their OMP First 2 harness. Will the difference in friction resistors make that much of a difference? |
11-21-2023, 01:31 PM | #2 |
Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
I'm not sure tbh, I bought a cheap corbeau harness and it's worked fine for me. I'm actually going to throw it on the passenger side and I'm buying a new one for the drivers seat. This time I'm going with some on blackfriday sale at ogracing, not sure how good they will be but I assume it will be just fine.
11-21-2023, 03:56 PM | #3 |
Nice, I didnt imagine getting an expensive harness was needed. Going to just grab one on a good deal
11-22-2023, 09:07 AM | #4 |
Drives: '23 2SS1LE Join Date: Sep 2022
It's more than just the friction resistors. The belt material itself is softer/more flexible in the Schroth harnesses I've used. The adjustment mechanisms are also easier to use in some of the more expensive "enduro" harnesses.
11-23-2023, 11:15 AM | #5 |
For sure get one that is the "pull-down" type or can be converted to it.
check out https://competitionmotorsport.com/co...43206326255835 use code COPSE$200OFF for $200 off
11-23-2023, 11:19 AM | #6 |
CMS Roll bars are also on Black Friday sale
https://competitionmotorsport.com/co...43236672209115 USE CODE: CMS23% |
11-24-2023, 09:53 AM | #7 | |
And good info on the harness. I like OMP, im going to get their seat, so ill look to see which of their harnesses are better |
