Old 03-17-2018, 10:17 AM   #15
Infern0
Bring It
Infern0's Avatar
Drives: In Between
What the... Waiting for results!
2017 Camaro ZL1 M6 - Everything but the sunroof - Sold
2010 Camaro SS - 650RWHP Daily Driver - Traded
Infern0 is offline   Reply With Quote
Old 03-17-2018, 11:39 AM   #16
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
Basically just unscrew that set screw/allen all the way out, then tighten it so that it's either BARELY touching the rod or barely NOT touching the rod, shouldn't hurt either way.
As long as it's not screwed way into the rod, forcing more dumped boost and whatnot, you're fine. I'd just unscrew it and then screw it in to a papers width from the rod.
*EDIT*
Just read Lt1z350's post. Lots of information in there. Would be very interesting if some of these adjustments could be made to multiple cars at a time and backed up with strip and dyno numbers. You're getting boost numbers as high as pulleyed cars.
Old 03-17-2018, 12:07 PM   #17
Tampabucs4
Tampabucs4's Avatar
Drives: 2018 blue ZL1
So back this screw away from the metal piece then movie back just touching barely.
Tampabucs4 is offline   Reply With Quote
Old 03-17-2018, 12:16 PM   #18
Can'tHave2MuchHP
Drives: Fast
Yes. It is highly likely it will do nothing for a majority of these cars.
Old 03-17-2018, 12:36 PM   #19
Badmojo
aka BeastZL1
Badmojo's Avatar
Lt1z350,
Thanks for posting the data logs. I can't believe how much the throttle is closing. It now makes sense why a tune is picking up so much HP and why ported throttle bodies work so well (basically tricking the computer by allowing more air for a given throttle position.)
It looks like the factory control strategy is attempting to keep a constant MAF Hz, which would theoretically be torque control.
For the record, I appreciate you sharing information.
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Old 03-17-2018, 04:27 PM   #20
VAZL1
VAZL1's Avatar
Drives: 17 ZL1
Looks like I'll be tuning sooner than I thought
2017 ZL1 Coupe M6, Red Hot
Mods; AFE Pro 5R CAI, Kong Ported Blower and Snout, NW 103 TB, Griptech 2.31 Upper, Kooks 2",JMS Voltage Booster, Flex Fuel, Mighty Mouse CC,Jannetty Racing Tune, 680 rwhp
VAZL1 is offline   Reply With Quote
Old 03-17-2018, 04:57 PM   #21
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Mine needed a half turn. Bring a 5/32 allen wrench.
Old 03-17-2018, 07:45 PM   #22
Blackdevil77
Blackdevil77's Avatar
Drives: 2008 Pontiac G8 GT, Shelby GT500
Do you have to re-apply that blue epoxy looking stuff once you turn it?
Blackdevil77 is offline   Reply With Quote
Old 03-17-2018, 08:19 PM   #23
Badmojo
aka BeastZL1
Badmojo's Avatar
Originally Posted by rjacobs View Post
I just went and checked mine. It was blue lock tite'd in place. I backed it out and it basically immediately lost contact with the little arm for the canister. I screwed it back in until it JUST touched. I MAY have it 1/8-1/4 turn further out than it came from the factory.
Same here. I had some blue loctite on hand so I put a drop back on.
2019 Camaro ZL1 1LE
Old 03-17-2018, 10:31 PM   #24
Boosted4life
Drives: 2018 ZL1 A10
I backed mine out about half a turn. No change in boost on the car's gauge. Can you elaborate on which lines you are blocking on the solenoid?
Boosted4life is offline   Reply With Quote
Old 03-17-2018, 10:32 PM   #25
waterman
waterman's Avatar
Drives: Grandad's C2 L89
subscribed
2018 ZL1 1LE sw/PDR
Old 03-18-2018, 06:24 PM   #26
ninetres
ninetres's Avatar
Drives: Crush ZLE M6 | 2000 Corvette FRC
FWIW I checked/adjusted mine today. I backed it off until I could see a gap, and then tightened it until it appeared to have just made contact. Looks like the net result was slightly over 1/4 turn back from where it was originally. The darker blue “blob” was at the top before adjustment. Added a drop of blue loctite myself once complete.
ninetres is offline   Reply With Quote
Old 03-18-2018, 07:57 PM   #27
boostednut
Drives: Nothing cool atm
Can anyone else do logs to see what's happening before and after this? It's pretty interesting. Definitely something there. But I want to see more logs of various cars
boostednut is offline   Reply With Quote
Old 03-18-2018, 08:19 PM   #28
ninetres
ninetres's Avatar
I didn’t log mine before although I may have one saved on my buddies laptop from our dyno session (my throttle stayed 98% FWIW on all pulls).
I don’t expect my cars performance to change honestly. I don’t think 1/4 turn will do much of anything. And I feel like my cars boost stayed pretty deep in the gauge beforehand.
adjustment, boost, bypass, lt1z350
