Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LLT Engine, Exhaust, and Bolt-Ons
Old 02-12-2024, 07:33 PM   #15
Bigalamo
Bigalamo's Avatar
Drives: 2011 LS Camaro
Originally Posted by bsn View Post
That sounds like a seized idler pulley or something. Make sure your AC is off to take compressor out of the picture, then remove your belt and turn your idler pulley by hand feeling four roughness. Turn your water pump by hand-if its been leaking for a while it may have washed the grease out of the bearing and its now seizing. A seized pully or water pump bearing will make that sound and also take far more current to start making it act like a bad starter-battery.
That makes a lot of sense. It’s dark and raining right now so I will do this tomorrow. I appreciate the response!
Bigalamo is offline   Reply With Quote
Old 02-21-2024, 07:45 PM   #16
Bigalamo
Bigalamo's Avatar
Update: Alternator replaced/all pulleys checked and still has this noise. Sounds like it’s coming from inside the engine, like a piston scraping the cylinder walls or something. Seems like the engine is done.
coolant, fuel, no start, shuttering
