Roto-Fab
Old 05-31-2013, 11:06 AM   #1
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
Maggie with stock tune, Skip shift tuned out?
Does anyone know if they tuned out skip shift in the Maggie kit? Can you tune it out?
I don't think I've had the 1-4 warning since I put it in. Or maybe the Maggie just puts some parameters out of range to trigger the skip shift?
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
Old 05-31-2013, 11:13 AM   #2
Medi0cr3
Untamed Performance EPT
Medi0cr3's Avatar
Drives: 2011 2SS
I think there's 3 parameters that have to be met in order for skip shift to come on. Although I could be mistaken
Throttle Position
RPM
Speed
Maybe your not meeting all 3 of those anymore
I sure know for a fact I dont meet them with my 4.11 rear end gears.
Night Fury Cam
Borla LT Headers and Borla Cat Back ATAK
9in. diff with 4.11's, DSS Axles, and Alum Shaft
Hurst Short-Shifter; Ideal Garage Master Cylinder
H-E Street Slayer Twin Billet Clutch
BMR: Adjustable; Trailing Arms, Toe Rods, Extreme Sway Bar. BMR Subframe Bushings.
Strange Rear Coilovers and mounts
Tuned by Rhino79
Medi0cr3 is offline   Reply With Quote
Old 05-31-2013, 12:07 PM   #3
carlos@redline-motorsport
Drives: 98 Z28
Do you miss it?
carlos@redline-motorsport is offline   Reply With Quote
Old 05-31-2013, 12:44 PM   #4
SSMickey
SSMickey's Avatar
Drives: 2010 IBM 2SS
Throttle Position
RPM
Speed
Actually, there are 4 parameters,
Throttle position
Coolant temp
Vehicle speed
Baro
Most tuners just set the coolant temp to a temperature the car will never reach so CAGS never enables.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 05-31-2013, 12:48 PM   #5
willhe64
willhe64's Avatar
Thanks Mickey, so it can be tuned out.
Old 05-31-2013, 01:10 PM   #6
Medi0cr3
Medi0cr3's Avatar
Drives: 2011 2SS
ah nice info SSMickey!
Night Fury Cam
Tuned by Rhino79
