dave@hennessey
Old 05-27-2013, 05:45 PM   #1
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
Intercooler/Ice box
What ice are you using tap water ice are dry ice? Going to be adding a ice box soon i can get dry ice would it be better and last longer??? Is there a reason not to use dry ice?
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
Old 05-27-2013, 05:55 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
Drives: ...and they're both wrong
Dry ice is made of frozen CO2, it wouldn't really help with cooling or at least I don't think it would.
Click to view my build thread
The Stig is offline   Reply With Quote
Old 05-27-2013, 06:29 PM   #3
FrankT
400HP used to be enough..
FrankT's Avatar
Drives: 2010 2SS rs manual
I don't know why you couldn't, but I would think having to vent the box would be the main one. When it changes states from solid to gas I would think it would pressurize the box. I would also think you would still use a water bath with the dry ice in it. Any physicists on here?
FrankT is offline   Reply With Quote
Old 05-27-2013, 06:30 PM   #4
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Drives: 2010 LS3 2SS
LME 416 LS3 shortblock/Callies Compstar 4340 4"crank/Callies 6.125 H beams rods/Wiesco 4.07 forged pistons/Cam Motion custom LS1/LME ported heads /maggie TVS2300/I West 8rib 10%OD /3.2 pulley/OD cog drive/JRE tensioner/ID850 /ADM dual fuel/Kooks LT 1 7/8/magna flow2.5 /cat delete/Roto Fab CAI /MGW short throw /SPEC super twin clutch/G Force built trans,carbon syncro rear shaft upgrade /DSS 9"single CF DS /Strange 3.70/31 spline trutrac/MT DR's/earls oil cooler /tuned KHC
Mchlgrrsn is offline   Reply With Quote
Old 05-27-2013, 06:33 PM   #5
The Stig
The Stig's Avatar
The pressure is what would be the issue. Also that once the dry ice turns to gas it doesn't really have any cooling effects. Where as when regular ice melts the water still cools (due to water having an extremely high specific heat).
Old 05-27-2013, 06:46 PM   #6
FrankT
FrankT's Avatar
True. You might get greater initial cooling, but when the dry ice is gone, it's gone. Plus you would lose volume in the ice box as the dry ice evaporated.
Old 05-27-2013, 06:49 PM   #7
The Stig
The Stig's Avatar
Well not necessarily. Remember PV=nRT. So if volume (because its a closed container) and amount of dry ice stays the same. As the pressure increases so would the temperature - so once the dry ice melts it'd actually start warming the coolant.
Old 05-27-2013, 06:54 PM   #8
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Where is that physicist when we need one. Lol
Old 05-27-2013, 07:23 PM   #9
Mr. Nasty
Mr. Nasty's Avatar
Wow sound like the dry ice is a no. Even for one pass at the time. And where is the physicist??? Its good for cold beer as long as you have the gloves.
Old 05-27-2013, 07:29 PM   #10
swiftkart
swiftkart's Avatar
Drives: 2010 SS/RS LS3 M6
Not sure how you plan on using the dry ice, but it's -109 deg and water freezes at 32 deg so that could case a problem if you don't think it through, but if you can figure out how to use it with a pressure vent on the tank like radiator cap or blow off valve of some sort, it would be colder than anything else within reason.
swiftkart is offline   Reply With Quote
Old 05-28-2013, 07:09 AM   #11
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
this was discussed long ago, dry ice is to unstable and will not work,,,supercharged ss has a ice box, he might give you some tips on what he founds works for him..
mikepage0007 is offline   Reply With Quote
Old 05-28-2013, 07:26 AM   #12
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Thank you. No dry ice. Superchargedss says put the ice in 5 mins before race time, keep it in support vehicle as you can't dump water out there. Lol I asked him a few days ago.
Old 05-28-2013, 08:49 AM   #13
SC2150
Drives: 2012 Camaro RS, RX supercharged
RX Superchiller and never hassle with any mess again....and no ice can cool as low and as efficient. Ice also adds a ton of weight, RX chiller adds app 19# and that's it.
We used to mess with ice years back, but the weight (every 100# is a tenth in the 1/4 mile) and then draining and refilling and the cost to keep buying ice every time.
SC2150 is offline   Reply With Quote
Old 05-28-2013, 09:45 AM   #14
H-E
Drives: 2010 zr1 Camaro 2011 vert
Dry ice does work and works well enuff to freeze the water,we add alchol to keep it from freezing,it is a hassle.When using ice you need to make your own with distilled water,a bag of ice has harmfull deposits that will gunk up your intercooler and build heat when the ice is gone. The best way to go is a seperate compartment to hold the ice and kool your super charger water .I have a few things drawn up for us but i havnt had the time to get them built.
H-E is offline   Reply With Quote
