Old 04-04-2018, 11:28 AM   #1
TurboBeezer
TurboBeezer's Avatar
Drives: 2018 Camaro ZL1 6MT
500 Mile Oil Change
Just got done doing a 500 mile oil change because I'm paranoid like that. 10Qts Mobil 1 Extended Perf 5W-30 and PF64 filter.
TurboBeezer is offline   Reply With Quote
Old 04-04-2018, 11:42 AM   #2
Oil Man
Oil Man's Avatar
Drives: 2016 2SS, 2018 ZL1 A10 (RIPx2)
I don't think it's paranoid. I found a noticeable difference between the color of the oil on the dipstick the night I drove off the lot vs. my 500 mile oil change last week. It darkened noticeably in those several days, though it may not have been as dark as in your photo.
It makes good sense. There's going to be assembly lubes and possibly even some metal from the machining process (hopefully not) in with that factory fill of oil.
I am trying to find documentation to support the 1500 mile change. I filled with Mobil1 at 500, am approaching 1500, have zero discoloration, have lost zero oil, and the DIC says I have 91% oil life remaining. I'll do it if I must, but it's kind of hard to see a strong NEED for it right now.
Oil Man is offline   Reply With Quote
Old 04-04-2018, 11:50 AM   #3
baron95
2018 1LE, NASA Instructor
baron95's Avatar
Drives: 2018 Camaro SS 1LE
I split the difference and did both first oil change and first diff fluid change at 1,000 mi
baron95 is offline   Reply With Quote
Old 04-04-2018, 11:58 AM   #4
silverbullet415
silverbullet415's Avatar
Drives: 2018 Camaro ZL1 1LE
Did mine at 500 and it was nasty, doing another change at 1500 and sending it out to get tested
silverbullet415 is offline   Reply With Quote
Old 04-04-2018, 01:57 PM   #5
TurboBeezer
I'm definitely glad I did it after seeing the color of the oil at 500.
Old 04-04-2018, 02:19 PM   #6
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
It's not paranoid to change at 500, it's normal and recommended. Don't neglect your diff. I'd change that at 500 too.
Old 04-04-2018, 02:27 PM   #7
TurboBeezer
True! I was going to do the oil again at 1500 as well as the diff. Should I instead do it at 500 then again at 1500?
Old 04-04-2018, 02:54 PM   #8
Can'tHave2MuchHP
Drives: Fast
I'd change both Oil and Diff at 500 and 1500 miles. So yes.
Old 04-04-2018, 03:58 PM   #9
likerage
I did oil at 1k and diff today at 2k and both were very dark. I have an average 18mpg since mile 17 so I don't exactly beat it up either.
likerage is offline   Reply With Quote
Old 04-04-2018, 04:11 PM   #10
Intimidator
Drives: 69 GTO, 05 GTO, 2018 Silver ZL1
Just did my 500 mile change and will do the next at 1500 also.
Intimidator is offline   Reply With Quote
Old 04-04-2018, 04:56 PM   #11
Jeffro19
Jeffro19's Avatar
I also did mine at 500 miles. Mine just turned 1500 so break in is complete and I will change it again soon then go to every 3000 miles. That’s always how I change the oil in all my new cars I buy.
