dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Dragstrip and Launch Techniques Discussion
Old 05-01-2012, 02:27 PM   #1
Merc
In The Circle
Merc's Avatar
Official 60 ft/time 2010+ Camaro Fast List
Anybody can spend money to make power but not everyone can make proper use of it. The most important part of drag racing is getting out of the hole. Improvements in your 60 ft. can net even larger gains by the end of the track. We already have a great 1/8 and 1/4 mile database that shows just what these cars of capable of, now let's see who is making the best use of their power and what components they are using to do it!
This list will be divided into three categories - drag slicks, drag radials, and street radials.
Street tires will consist of OE radials or any DOT street compound radial, regardless of size. Tire must have a 200+ treadwear rating to fit into this category.
Drag Radials will consist of any brand or size DOT approved Drag Radial. Examples include BFG Drag Radials, Mickey Thompson ET Street Radials, M&H Racemaster Drag Radials, Nitto NT05R & Nitto NT05, Hoosier Drag Radial.
Drag slicks consists of bias-ply slicks or treaded "cheater" slicks such as Mickey Thompson ET Street, Hoosier Quick Time Pro, or M&H Racemaster tires.
RULES:
To be officially listed, please post a scanned timeslip documenting your time. If you have a problem posting your time slip send me a PM and I will help you get it posted.
In addition to a timeslip, please cut and paste the following into your post and fill out the form:
60 ft/time:
Tire Brand/Type:
Tire Size:
Suspension Upgrades:
Drivetrain Upgrades:
Automatic or Manual transmission:
Rear Gear Ratio:
This thread is reserved to OE-type cars with IRS rear suspension. The list will cap at 20 entries per category and will be updated weekly. If anyone has any questions or suggestions please feel free to send a PM.
STREET TIRES
https://docs.google.com/spreadsheet/...Wc&usp=sharing
DRAG RADIALS
https://docs.google.com/spreadsheet/...FE&usp=sharing
DRAG SLICKS
https://docs.google.com/spreadsheet/...EE&usp=sharing
Old 05-01-2012, 03:27 PM   #2
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
We will kick it off:
60 ft/time: 1.439
Tire Brand/Type: Mickey Thompson Drag Radial
Tire Size: 305/40R18
Suspension Upgrades: Full BMR - Adjustable Trailing Arms, Adjustable Toe Rods, Adjustable Control Arms, Anti-roll Bar, Subframe Conectors, Tunnel Brace, Delrin Cradle Bushings, Delrin Differential Bushings
Drivetrain Upgrades: G-Force 300M Axles, G-Force 9", PST custom 4" aluminum driveshaft
Automatic or Manual transmission: TH400 Auto
Rear Gear Ratio: 3.90
BMR guy is offline   Reply With Quote
Old 05-01-2012, 03:32 PM   #3
Supercharged SS
Drives: 2010 Camaro
60' time: 1.44
Tire Brand/Type: Hoosier / Quick Time Pro
Tire Size: 28 x 14.50 x 16
Suspension Upgrades: Pfadt Trailing Arms
Drivetrain Upgrades: DSS 1000HP axles, DSS 1 piece aluminum driveshaft
Automatic or Manual transmission: JRE built 6l80e
Rear Gear Ratio: 3.45
Supercharged SS is offline   Reply With Quote
Old 05-01-2012, 03:34 PM   #4
blufin
blufin's Avatar
Drives: Fire Engine
60' list
Tire Brand/Type: Stock Pirelli P zero
Tire Size: 275/40/ZR20
Suspension Upgrades: None
Drivetrain Upgrades: None
Automatic or Manual transmission: M6
Rear Gear Ratio: Stock
This slip is post supercharger. Pre supercharger the best 60' was a 1.87
12.618 @ 110.75 Bone Stock 1/4 mile
8.165 @ 86.52 Bone Stock 1/8 mile
11.189 @ 124.44 on a 1.73 60' TVS2300 3.4 pulley, JRE tuned, Kooks LT headers and HF cats, MBRP catback exhaust, CAI intake, ADM scoop. Stock wheels/tires.
Sold
blufin is offline   Reply With Quote
Old 05-04-2012, 10:01 AM   #5
Padre
Only drives on Sundays
Padre's Avatar
Drives: '16 2SS A8 NPP MRC NGray
60 ft/time: 1.565
Tire Brand/Type: Mickey Thompson DR's
Tire Size: 305/40-18
Suspension Upgrades: BMR 1" lowering springs, rear sway, diff bushings, trailing arms
Drivetrain Upgrades: none
Automatic or Manual transmission: 6L80E, stock
Rear Gear Ratio: 3.45 (from stock M6)
Bottom right:
Padre
OLD HOTNESS: The "Heretic": '11 2SS/RS L99 A6 Black/Inferno. Build Journal, Videos
D1SC GT9 JBA-LT = 720/680 | 10.330 @ 133.61, 1.546 sixty... Camaro King at ECS V, Darlington.
NEW HOTNESS: '16 2SS A8 NPP MRC. Bone Stock, 1/8th: 8.051 @ 89.44, 1.919
Padre is offline   Reply With Quote
Old 05-05-2012, 02:21 PM   #6
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
60 ft/time: 1.567
Tire Brand/Type: nitto 555r
Tire Size: 305/45/18
Suspension Upgrades: BMR trailing arms/toe-rods/bushings: eibach springs
Drivetrain Upgrades: DSS axles
Auto
Rear Gear Ratio: stock 3.27
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 05-07-2012, 01:59 PM   #7
nyny69
Drives: 2010 IOM SS
60 ft/time: 1.564
Drivetrain Upgrades: DSS axles, 1 Piece Driveshaft
Auto
nyny69 is offline   Reply With Quote
Old 05-09-2012, 09:12 AM   #8
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
Looks like we have a battle going in the Drag Radial section: 1.564, 1.565, and 1.567 - those are some close times!
Old 05-10-2012, 03:53 PM   #9
lexlueger
lexlueger's Avatar
Good suspension pieces! I have a lower 60..can't find the slip!
CUSTOM CAM
TPIS 102 TB
NX EXPRESS/NANO KIT
KILL MODE, ON.
Old 05-10-2012, 03:59 PM   #10
BMR Sales
BMR Sales's Avatar
Drives: Race Car
That gives you a good reason to go out there and get some more time slips!
Old 05-10-2012, 04:12 PM   #11
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
60 ft/time: 1.567
Auto
I noticed you filled out 3.27 for your gear ratio but in your sig it says 3.70's...
Old 05-10-2012, 04:16 PM   #12
lexlueger
lexlueger's Avatar
Just got those installed. I haven't made a pass with the 3.70's yet.
CUSTOM CAM
TPIS 102 TB
NX EXPRESS/NANO KIT
KILL MODE, ON.
Old 05-14-2012, 09:10 AM   #13
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
Nice. Keep us updated!
Old 05-14-2012, 09:23 AM   #14
cam99
cam99's Avatar
Drives: 2012 ZL1
mine
60' 1.6931
tire brand: hoosier drag radials
suspension: stock
drivetrain: stock
transmission: M6
rear gear: stock
Fastest dr M6 in the sticky (only dr M6 in the sticky LOL)
2012 CTF ZL1-stock
2012 ZL1 (sold)
JRE 75rwhp kit
catless
ported lsa TB
11.04 @ 128.35
on hoosier drs and skinnies
@ PRP with 1100DA
cam99 is offline   Reply With Quote
