Old 01-30-2017, 11:50 AM   #29
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Originally Posted by KaBoom1701 View Post
Good luck with the tires sizes of thr R888...
only 285 and 315....
I've been running GY's for the past 3 yrs worth of track days. I'm going to try the MPSS next and see how they respond at the track.
Be sure to let us know, you'll probably get to it before I do.
Old 01-30-2017, 11:59 AM   #30
Thor142
Thor142's Avatar
Drives: 2014 2LS (traded in) 2015 1SS 1LE
Originally Posted by Evolvedx27 View Post
Nothing wrong with OEM tires but when they go bald in 10-15k miles you might want something that lasts twice to three times as long with same or better performance.
Where do they sell these magic tires?
Thor142 is offline   Reply With Quote
Old 01-30-2017, 12:03 PM   #31
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
Originally Posted by URBAN LEGEND View Post
A 315 is a different size by different manufacturers. You must know the Brand. A 325 Bridgestone is really a 315 for Michelin. All real world experience.
Yes they vary slightly. However, if they are advertising 315, then it's "close" for everyone. The 315 is one of many standard measurement and no manufacturer can be too far off from the advertised size of a tire.
And specifically for the R888 argument that goes back to Camaro5 with KaBoom complaining about millimeters, the R888 looks IDENTICAL to the OEM F1s that are on the 5th Gens from all angles (Except the tread is different), and more than likely, zero changed between those and these new ones as far as height, width.
This goes back, keep out if you don't know Unlike quite a few people, I'm not just going to post BS info that I just "read" from somewhere or some article written by a guy in a tie at a magazine.
Old 01-30-2017, 12:10 PM   #32
URBAN LEGEND
URBAN LEGEND's Avatar
I know it wasn't towards me. I was just putting it out there. I run 325/30s upfront on my Z/28. But it's the right brand. All good bro.
🔺22 RS E TRON GT
🔺21 Model S Plaid
URBAN LEGEND is offline   Reply With Quote
Old 01-30-2017, 12:16 PM   #33
Can'tHave2MuchHP
Drives: Fast
Love how the Z28 runs those monsters up front, hope they keep it for the new Z28 too.
Old 01-30-2017, 12:17 PM   #34
00 Trans Ram
00 Trans Ram's Avatar
Drives: 2017 2SS
Guys, you have to look past the numbers when comparing tires.
315/30-20, TW300
That size means:
315mm section width. This is the measurement of the widest portion of the tire. Not the tread, but at some point in the middle of the sidewall. If you want to know the width of the part that touches the ground, you have to find tread width. Hoosier regularly publishes this, but it can be hard to find on other tires. However, even within the same brand and model of tire, these 2 items (tread and section width) don't always go hand-in-hand. Just because something is 20mm wider in section width, doesn't mean it's always going to be 20mm wider in tread width.
30 - This is a percentage. This means that the sidewall is 30% as tall as the section width. So, a 30-series tire means that EACH sidewall is 94.5mm tall. Or, 3.72".
20 - Obviously, rim size. To find overall tire height, you have to solve 3.72*2+20, which is 27.44".
TW300 - Treadwear is an almost meaningless number. Within the same exact tire model, if you find 2 different treadwear numbers, then you can compare them. For instance, if you find a PSS with a 300 TW and another PSS with a 200 TW, then you can be relatively confident that the 300 will last 50% longer. But, you can't begin to compare a TW300 PSS and a TW300 Nitto. Tire manufacturers are not required to submit their tires to any standardized test for treadwear or tire life. These numbers are simply a standardized number, but only relative for comparison within specific model ranges.
Take a look at any SCCA "Street tire" forum, and you'll see that, ostensibly, tires have to have a UTQG rating of 200 (that's TW rating). But, keep reading the forums, and you'll soon learn that some of those "TW200" tires are little more than racing slicks that have a "200" printed on the side.
00 Trans Ram is offline   Reply With Quote
Old 01-30-2017, 12:20 PM   #35
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Will do.
I'm thinking of going with 295's up front and 315's in the rear.
Might help keep this heavy car from "pushing" so much in the corners at the track....we'll see.
Well according to my 8th grade math skills that's a 3.2% bigger tire patch on the ground....and I need all the rubber out back with the mods I'm running now.
To each their own I guess.....
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats.
KaBoom1701 is offline   Reply With Quote
Old 01-30-2017, 12:23 PM   #36
Can'tHave2MuchHP
Drives: Fast
Will do.
Wider is better, it's never going to hurt (To an extent, let's not go crazy here). But "Good luck with a 285 and 315" doesn't seem to imply you want wider, as both are already wider than the OEM sizes.
Old 01-30-2017, 12:53 PM   #37
Evolvedx27
Evolvedx27's Avatar
Drives: 2017 ZL1
not magic... tire rack is great site for info. along with many other sites...
Evolvedx27 is offline   Reply With Quote
Old 01-30-2017, 01:27 PM   #38
Thor142
Thor142's Avatar
What tire is it that you think is going to last 2-3x longer with the same or better performance than the GY G3?
Old 01-30-2017, 01:45 PM   #39
17CamaroZL1
Life's Short, Live Fast!
17CamaroZL1's Avatar
+1
I want them, whatever they are
Life's Short, Live Fast! https://youtu.be/rTUv2p4T7OA 10.94 at 128 mph, 11.13 at 127mph 870 DA, https://youtu.be/e_X_LcpFp50 11.19 at 127mph 1100 DA, https://youtu.be/OXQiCQdQuH4 11.40 at 125mph 1800 DA
https://youtu.be/uWba1qs8M6Q 11.52 at 123mph 3500 DA
12/26/2016 Ordered!
2/8/2017 Built!!
3/2/2017 Brought Home!!!
Old 01-30-2017, 01:46 PM   #40
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
The MPS4S claim 9% but we'll see how this holds up at the track.
http://www.michelinman.com/US/en/tir...-sport-4s.html
Mods:
Old 01-30-2017, 02:28 PM   #41
Evolvedx27
Evolvedx27's Avatar
Drives: 2017 ZL1
In my opinion, my experience, and from research. the Michelins. Track is out of the question. Street only. 10 x3=30. 15x2=30. Even if it's not the same performance better treadlife may be worth a small performance loss. Again street only. All depends on what you're doing with the car.
Old 01-30-2017, 02:46 PM   #42
Mr. Wyndham
Will do.
I didn't know it had a pushing problem...in fact, I've read it's really well behaved? Certainly felt really good during the ride.
In any event - if you want to combat understeer...going wider on the rear isn't going to help. This is the reason the Z/28 stuck with 305s on all four corners.
It's also the reason they increased the front track width a bit, yet decreased the rear on the ZL1 vs the SS...to improve front-end bite.
