TireRack
Old 12-06-2020, 05:52 PM   #1
cdb95z28
cdb95z28's Avatar
For those with the 6 piston Brembos, Cheaper Brembo 2 Piece Rotor option
I found this on Rockauto.com.
Brembo now has their own aftermarket 2 piece ZL1 rotors. They look identical to their same 2 piece rotors they supply GM with.
I have purchased them and they have the same vent design, vane count and the same hat and fasteners The finish looks the same.
BREMBO #09A66513 Left
BREMBO #09A66523 Right
Prices sometimes change on RockAuto, but they are currently about $170 each, compared to the GM sourced Brembos at about $290. Also rockauto's inventory changes. As of 4/27/21 they only have the LF rotor. But shop around you can still find them for good prices.
It is possible that the cast iron is different, but everything else looks to be the same. As I mentioned, I have purchased a pair . I track my '14 1LE with the 6 piston front brakes and have no reservations with using these on track. They very well could be 100% identical but without the GM price surcharge.
https://www.brembostoreusa.com/produ...rotor/09A66513
https://www.brembostoreusa.com/produ...rotor/09A66523
Old 12-06-2020, 08:26 PM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
I have seen those before an posted about, seems like a real bargain. What are you going to do with your old rotors?? I need hats an hardware.
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components.
olblue75 is offline   Reply With Quote
Old 12-09-2020, 09:30 AM   #3
cdb95z28
cdb95z28's Avatar
Not sure yet, I have so much stuff that I should sell. Are you doing the DBA rings?
Old 03-20-2021, 05:37 AM   #4
Tmcgee2010
Tmcgee2010's Avatar
Drives: 2014 SS 1LE
Thanks for the info, im saving this for when I pry open my wallet and finally swap to 6 pistons.
Question though, is there a 2 piece rotor option for those of us still on 4 pistons?
All i can find are the drilled and slotted stuff.
2014 1LE
cold air inductions
kooks
BTR stage 4
UDP
GPI ported Tb & manifold
491whp pump
510whp E85
715 whp RCSB silverado for the straight line stuff
Tmcgee2010 is offline   Reply With Quote
Old 03-20-2021, 12:41 PM   #5
cdb95z28
cdb95z28's Avatar
Yes, but they are out of stock and expensive.
https://www.morrisengineering.com/camaro/
For the money, the 6 piston setup is great.
Old 03-20-2021, 12:43 PM   #6
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Look to Racing Brake for 2 pc rotors possibly?
Orange Krush II
Old 03-20-2021, 12:47 PM   #7
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
I have the RB rotors and love them. They're an expensive option but you drop like 40 lbs if memory serves of rotational mass for the full 4 rotor set. I have no regrets.
Sent from my SM-N986U using Tapatalk
Firefighter is offline   Reply With Quote
Old 10-05-2021, 01:19 PM   #8
Fanch1LE
Fanch1LE's Avatar
Drives: 2015 1SS 1LE
Thanks for the info. I ordered these Brembo rotors. Also picked up some 6th gen SS 1LE 6 piston calipers 172-2741 and 172-2742. It was tough to pass on the Corvette calipers with vented pistons, but since I have a 1LE I chose to stick with these. Can always swap the pistons later.
Fanch1LE is offline   Reply With Quote
Old 10-06-2021, 09:14 AM   #9
MaverickLS7
MaverickLS7's Avatar
Drives: 2015 1LE
Just ordered everything from RockAuto 2 days ago, I went with the vented Z calipers tho. I'm glad I came across this post because I was unsure if these Brembos actually came with the hats, couldn't find out through RA.
MaverickLS7 is offline   Reply With Quote
Old 10-06-2021, 02:27 PM   #10
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
I scored a set of 6th Gen 1LE upgrade rotors an just transferred them to a set of 5th Gen hats.
Orange Krush II
Old 05-23-2022, 10:28 AM   #11
cdb95z28
cdb95z28's Avatar
Quick update, I ran these Brembo brand rotors on track and IMHO they worked just as well as the GM/Brembo rotors.
Old 05-23-2022, 10:30 AM   #12
cdb95z28
cdb95z28's Avatar
Looks like Brembos website price on these went way up but they are still a fair price on rockauto
EDIT, well rockauto's price on the GM/Brembos are cheaper, lol. Oh well, I bought them at a good time!
