Vararam
Old 10-29-2013, 02:49 PM   #1
Jims Mongoose
Jim
Jims Mongoose's Avatar
Drives: 2013 Black 2SS 1LE
Is this really true?
I just got a slow leak in one of my tires on my 1LE. Only about 4000miles on them.
Took it to Chevy and they said it had a nail and could not be fixed so I needed a new tire. Is that really true, you can repair that tire?
Jim
Jims Mongoose is offline   Reply With Quote
Old 10-29-2013, 02:52 PM   #2
rickr9504
rickr9504's Avatar
Drives: 2018 Camaro 2SS 1 LE
I have repaired mine. no problem since. It depends of the location of the nail or screw. If it is on the sides of the tire then you are pretty much screwed and need to replace it.
rickr9504 is offline   Reply With Quote
Old 10-29-2013, 03:04 PM   #3
Vbh_1LE
Drives: Victory Red 2013 Camaro 2SS/RS 1LE
The tires are a very soft compound, and speed rated. The dealer doesn't want the liability of the repair. If it were me, I'd buy a new tire. I can't imagine driving 100+ mph on a tire with a patch, and possible core damage.
Vbh_1LE is offline   Reply With Quote
Old 10-29-2013, 03:04 PM   #4
MotorCity
MotorCity's Avatar
Drives: BRM 2SS/RS 1LE
I got a 2" long nail in the sidewall of my passenger side rear tire... this was with only 400 miles on the car I really didn't want to replace the tire this early, so....
I decided to pull the nail out and fill the tire with Fix a Flat. This is a temporary fix until the leak starts again. But so far my rear tire has held pressure for about 5 months now, and still going strong.
MotorCity is offline   Reply With Quote
Old 10-29-2013, 03:07 PM   #5
Aequitas & Veritas
Aequitas & Veritas's Avatar
Drives: 2010 Camaro 2LT RS, 2009 GTR
Like the others have said it all depends on how big it was. I've ran over small screws and had them patched. Previous cars though I had a massive industrial nail probably 7 inches long go in, I replaced that whole tire
Aequitas & Veritas is offline   Reply With Quote
Old 10-29-2013, 03:11 PM   #6
davidcroft
Sellin Chevy's since '06
davidcroft's Avatar
Drives: 18ZL1 02Z-28
'19 Z06-7Speed and lowered on stock bolts
'02 Z28-Kooks true dual headers/TSP heads&cam/full suspension & Kmember sub40K orig miles. https://youtu.be/h6faSdcvNew
TRADED!'17 ATS-V Coupe w/ Carbon Black pkg https://youtu.be/GH_t-R-TJV0
SOLD! '18 ZL1 Mosiac Blk
SOLD!'16 SS Sedan-Forgestars/ARH/rotofab
TRADED!2014 SS Sedan
SOLD! 2013 Blue Ray1SS/1LE 1of20.
TRADED! 2012 White 1SS/RS
davidcroft is offline   Reply With Quote
Old 10-29-2013, 03:47 PM   #7
redcbs
redcbs's Avatar
Drives: 2014 AGM 2SS/RS 1LE
If it's in the tread you should be ok. If it's on the shoulder or sidewall it will have to be replaced. I got a screw in mine at 900 miles and patched it (not plugged). No problems since
Sent from my SAMSUNG-SGH-I537 using Tapatalk
2014 AGM 2SS 1LE RS - On Order 8/23/13, TPW 9/9/13, Built 9/12/13, Shipped 9/17/13, At dealer 9/29/13, Received 10/4/13
2011 V6 DC 4x4 AT Tacoma
1985 NA MT 300zx
redcbs is offline   Reply With Quote
Old 10-29-2013, 03:51 PM   #8
Jims Mongoose
Jim
My dealer won't
My dealer will not repair a tire of this rating. Am I crazy to replace the tire with only 4000 miles on it when it is not in the sidewall?(I just checked on that just now).
They want $305 for the tire.
Jim
Old 10-29-2013, 03:52 PM   #9
cornerspeed92
cornerspeed92's Avatar
Drives: 2013 1SS 1LE
I got a nail at 300 miles.If it is in an area that can be patched thats fine,but dont track that tire.
cornerspeed92 is offline   Reply With Quote
Old 10-29-2013, 03:53 PM   #10
INtha305
Drives: 2010 camaro lt
i would replace it if i were you. thats not a regular cheap sears brand tire
INtha305 is offline   Reply With Quote
Old 10-29-2013, 04:41 PM   #11
Ajdin@A2BMotorsport
Drives: 2013 Camaro 1SS/1LE
I got a nail repaired in one of my rears, Ive taken it to a test and tune at the track and had no issues at all.
Ajdin@A2BMotorsport is offline   Reply With Quote
Old 10-29-2013, 05:13 PM   #12
detox
detox's Avatar
Drives: 2002 ss camaro
Riding very briefly on a flat tire will destroy inside sidewall.
detox is offline   Reply With Quote
Old 10-29-2013, 05:15 PM   #13
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Jim
Depends on where the nail is.....
....and if you intend to race your car.
If the nail is in the sidewall - you're about screwed, no pun intended. In NY, for example, it's illegal to repair a sidewall wound.
If you intend to use the car like it was built to do - you don't WANT to repair it, IMHO...ran into this issue with the ZL1. The repair becomes a weak point, and I wouldn't want any weak points @ 99 mph around a sweeper...
fwiw....
Old 10-29-2013, 05:16 PM   #14
Bmags
Bmags's Avatar
Drives: 2013 Camaro 2SS/RS SIM
I wouldn't run it for a Texas mile high speed event or some extended high speed endurance type event, but should be fine with a repair for most other uses. Any tire that has a high speed rating is no longer consider high speed capable for extend periods of time once a repair is made to the tire.
Bmags is offline   Reply With Quote
