Vararam
Old 10-21-2013, 07:31 PM   #1
Craig B
Craig B's Avatar
Drives: 2013 1LE
1LE Shifter?
Does anyone know if a ball type shifter handle can be used on a stock 1LE shifter? Looking to do something like this for the line lock http://www.phastekperformance.com/20...de-1630069.htm
Craig B is offline   Reply With Quote
Old 10-21-2013, 07:46 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
Drives: ...and they're both wrong
Stock shifter is pushed on - so no threads.
Click to view my build thread
The Stig is offline   Reply With Quote
Old 10-21-2013, 11:27 PM   #3
kansjfr
Drives: 2013 2SS 1LE
Wrong, wrong, wrong. On the 1LE (and on all '13s, I believe) the shift knob is held on with a setscrew that is only accessible after removing the boot from the shift knob. There's a thread on it, do a search. The original poster broke off the tabs inside the shift boot prying the knob and boot apart. I put a really cool knob from EPCO on mine, but getting the boot to mate with the shift knob was a pia and required some jerry-rigging (spelling?). You will NEVER get it off trying to just pull it off. I love the EPCO knob and how it looks, and don't have to worry about that stupid factory knob getting the nap worn off.
kansjfr is offline   Reply With Quote
Old 10-22-2013, 04:35 AM   #4
Craig B
Craig B's Avatar
Drives: 2013 1LE
Thanks for the info. I am going to give them a call today.
Old 10-22-2013, 06:37 AM   #5
The Stig
The Stig's Avatar
Really? Wow, did not know that. Is that new for the 2013's or for the 1LE's?
Old 10-22-2013, 06:44 AM   #6
SteveV
SteveV's Avatar
Drives: 2018 ZL1 Camaro 6M Red Hot
Hey Kans... Any pics of the knob?
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
SteveV is offline   Reply With Quote
Old 10-22-2013, 08:07 AM   #7
Fraxum
Fraxum's Avatar
Darn, I would like to replace my 1LE shifter and was hoping the 1LE knob would fit my OE Barton stick and shifter. I like the stock knob. As far as shifters go:
MGW > Barton > 1LE/ZL1 > Hurst > Stock SS
Old 10-23-2013, 10:42 PM   #8
kansjfr
I've taken a couple of pics of the knob on the shifter, trying to figure out how to get them from my digital camera to the computer (done, I think), and then to this thread. Patience, please.
Old 10-23-2013, 10:53 PM   #9
S3XPanther
by Odeon
S3XPanther's Avatar
Drives: '12 SS/RS A6 IOM SOLD, '13 1LE IOM
I found this on Epco's site. Prob one of the best they offer.
"It works 60% of the time, every time."
"Some say it's a waste of time, others say it's an incredible waste of time."
"The ultimate measure of a man is not where he stands in moments of comfort and convenience, but where he stands at times of challenge and controversy."
2013 IOM SS/RS - 1LE. Born 5/6/2013 (1 of 32 1SS IOM 1LE's)
S3XPanther is offline   Reply With Quote
Old 10-25-2013, 01:40 PM   #10
kansjfr
OK, I think I finally got the pics attached. I bought two of the Epco knobs, one has more white in it than the other. When you get the boot and factory knob separated, loosen the setscrew on the factory knob and remove it. Then put the the largest diameter sleeve they supply on the shifter shaft, but you'll have to gently grind or file down the outside of the sleeve so that the knob will go over it and the shifter shaft. Then put the knob on the shifter shaft with the sleeve on it and put the setscrews in and tighten them. After you get that accomplished, you'll need to file down those little pins inside the shift boot until they will friction fit over the collar with the setscrews on the Epco knob. You just have to keep filing down the pins a little at a time (I used a rat-tail file) until the shift boot will tightly fit over the collar that holds the setscrews on the Epco knob. I told you it was a jerry-rigged thing, but it looks great (to me, at least), and it's holding up well so far.
Old 10-25-2013, 03:12 PM   #11
detox
detox's Avatar
Drives: 2002 ss camaro
Leather or Fabric knob is much more comfortable.
detox is offline   Reply With Quote
Old 10-25-2013, 03:23 PM   #12
Fraxum
Fraxum's Avatar
I have had several knobs on my '11 SS and like the standard 1LE knob better than all the others. Barton will be making a '13 compatible stick so I can keep the stock knob and install my Barton shifter. That job is a PIA but worth it.
Old 10-25-2013, 04:51 PM   #13
kansjfr
OK by me.
Old 10-25-2013, 05:06 PM   #14
SteveV
SteveV's Avatar
That is a cool looking knob.
