Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 05-01-2015, 07:55 PM   #1
revobasher
revobasher's Avatar
Drives: 2013 ZL1
Car Trailer
I am in the market for a car trailer.. just curious what you guys are using? Anything specific I should look for? I am concerned with how low my car is with the 1" drop. Oh and I will be pulling the ZL1 with a 2002 Tahoe.
2013 ZL1 - Blue Ray Metallic
JDP 850 Package
740hp/700tq @14lbs on E85
Build Thread
revobasher is offline   Reply With Quote
Old 05-01-2015, 08:01 PM   #2
Redlineviper
Redlineviper's Avatar
Drives: 2013 ZL1
As long dove tail as possible, long ramps, and torsion axles for low ride height. If it's an open trailer low fenders or removable fenders so you can open the doors. 16' min but 20 is perfect as you can adjust car position for ideal tongue weight and get good strap angles. Electric brakes instead of surge brakes. Swivel jack and d ring hooks. I could go on and on.
2013 A6 ZL1
Redlineviper is offline   Reply With Quote
Old 05-01-2015, 08:22 PM   #3
revobasher
revobasher's Avatar
Drives: 2013 ZL1
Do you think a skid steer trailer would work? I can get access to one of those for free whenever.. It's a 16' and about 2800lbs... I am just not sure about the ramps.. prob need to use race ramps or something similar to get low enough.
JDP 850 Package
Build Thread
Old 05-01-2015, 08:27 PM   #4
Blk-Ice
750HP of Twisted Reaper!
Blk-Ice's Avatar
Drives: Blk 2SS/Blk Carb Fibr NS-1 stripes
.....i have to watch this thread because i have the same issue due to my body kit.
Fear the LMR Twisted Reaper Brotherhood!
Blk-Ice is offline   Reply With Quote
Old 05-01-2015, 08:42 PM   #5
revobasher
revobasher's Avatar
Drives: 2013 ZL1
In looking at skid steers, I am guessing most are not wide enough.
JDP 850 Package
Build Thread
Old 05-01-2015, 08:43 PM   #6
revobasher
revobasher's Avatar
Drives: 2013 ZL1
This is the one I have access to
JDP 850 Package
Build Thread
Old 05-01-2015, 08:56 PM   #7
Bigtime53
Bigtime53's Avatar
Drives: 2013 ZL1
I do not see any d-rings on the floor of the trailer. Where would you tie your car down to? I also think that trailer will be to heavy with your car on it to pull behind a tahoe. Just my thoughts.
Bigtime53 is offline   Reply With Quote
Old 05-01-2015, 09:00 PM   #8
Redlineviper
Drives: 2013 ZL1
The skid steer trailer will be plenty heavy duty but technically about as opposite of ideal as they come. That one has a 2' dove tail, skid steers have very short wheelbases so it's irrelivent for them. Second it has 8 lug heavy duty axles, which sit higher than standard 3k axles. Then the fenders are taller for the heavy duty tires. The trailer is super heavy duty which is fine but you are tugging an extra 1000lbs that you don't need. If it's free and a trailer you rarely use you should be able to use it, although it will take some effort. You will either need to crank the jack down to raise the front of the trailer to improve the approach angle or pull your tow vehicle up on some stepped boards. Then you will need to get a few 2x10's and stair step the approach for the ramps. None of this is hard or big deal but separates the ideal car trailer from a equipment trailer.
2013 A6 ZL1
Old 05-01-2015, 09:02 PM   #9
Redlineviper
Drives: 2013 ZL1
It has stake pockets on the side and you can hook the trailer frame by running the strap over the deck frame.
2013 A6 ZL1
Old 05-01-2015, 10:35 PM   #10
Trackman
Trackman's Avatar
Drives: 67RS Camaro ,Black 2013 ZL1
NO.
Your going to need a mile of boards or something to reduce load angle. The fender will not allow you to open the door. Your ZL1 is not a skid steer.
Drive it, race it, drive it home.
Trackman is offline   Reply With Quote
Old 05-01-2015, 10:59 PM   #11
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
tilt trailer!
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540
From Oklahoma, Join us on Facebook
https://www.facebook.com/groups/okcamaros/
SamHouseIII is offline   Reply With Quote
Old 05-02-2015, 03:36 AM   #12
TobysZL1
TobysZL1's Avatar
Drives: ZL1 Gone but not Forgotten!
Originally Posted by SamHouseIII View Post
tilt trailer!
AWESOME!!!!!!
Sent from my SM-N900V using Tapatalk
TobysZL1 is offline   Reply With Quote
Old 05-02-2015, 08:15 AM   #13
IDEALG
Chevy's "Rumble" Best!
IDEALG's Avatar
Drives: 2015 ZL1 6 speed
Send a message via AIM to IDEALG
I bought this one for under $3k
Still need to carry 2x6 planks to get it up without scraping the splitter.
IDEALG is offline   Reply With Quote
Old 05-02-2015, 08:33 AM   #14
Redlineviper
Drives: 2013 ZL1
tilt trailer!
You have a chicken that rides on your car?
2013 A6 ZL1
